S-10 IFS bagged question
OK, I have a Scott Danforth Cross Member going in a 1949 Chevy 3600. His cross member accepts S-10 and Metric donor parts.
The truck will be on bags. Last night I mocked up the S-10 donor parts. ![]() ![]() According to some rough measurements with a 27" tall tire, and stock spindles my running boards will be about 4" off the ground. I am loosing some travel due to the upper ball joint binding up. So the question is:
I plan on dehumping the Lower Control Arm to accept my bags. |
Re: S-10 IFS bagged question
Anybody???
Have you seen these http://michiganmetalworks.com/store/...&product_id=76
if you have the fab skills, i'm a fan of the pie cut factory parts. i like the look of factory parts in an obviously custom build vs custom parts in a factory car, plus it's like 1000x cheaper for the exact same function.
#5 | |
#6 | |
I think I am going to give them a shot...... |
Love those
I hadn't found those yet ... are they simply angled joints, or do they have more angular travel? |
#8 | |
gotcha, angled mounting flange ... same angular travel as stock.
just to make sure i have this clear in my head, you would still get the same total wheel travel with these, but that travel would be over a different range. the truck would sit lower at max, but not as high at max. if you need new ball joints, it's a pretty good option but the cut-n-weld is still virtually free and tune-able. when i cut mine, i trimmed the end of the x-member and ditched the lower bumps first. this let me use the physical stop of the lower arm hitting the x-member as my lower limit. then when i cut the uppers, they were bent to exactly match this lower limit giving me the maximum possible extension before that joint topped out again. i actually cut them, bolted them back into the suspension, sat on the x-member to hit the lower limit of the lower arms, bent the upper arm in place til it stopped, and tacked it back together. my way was a lot more work ... |
