![]() Join Date: Oct 2008
Contact Paper for Interior Woodgrain?
Has anyone used Contact Shelf Liner to replace the woodgrain on the instrument cluster, glovebox and door panels??? If so, can you please advise on the results??
I picked some up for like $5 at my local hardware store, it's a pretty dead-on match for the woodgrain... But it appears a little thin and I don't know how it will hold up in tHe heat / cold or over time.... Hoping for some info before I start to peel and stick. I attached a pic of it on the glovebox but I havent stuck it on there yet ![]() |
![]() Join Date: Oct 2009
Re: Contact Paper for Interior Woodgrain?
the texture won't be correct, it will feel like contact paper. BUT, it is a pretty good match visually. Can always rip it off if you don't like it.
I have a tip that requires some steady hands but, the adhesive backed glue will adhere much better if you bake the glovebox door in an oven just enough to get it really warm (but not too hot to touch obviously) then take your pre-cut liner and begin in one corner then slowly but evenly lay it out flat. The glue will bond MUCH better. But-be sure the surface is 100% free of any dirt/dust particle as well as paint defects-any surface imperfection will be magnified if you attempt to lay the contact material over it.
When I think of contact paper I think of curled edges. It will be exposed to heat about double what a kitchen drawer never sees. Some see fake wood as tacky, so what does that make a cheap fake woodgrain job... that I think will fail? They look fine w/o the woodgrain. If I did anything, I'd be sure it would hold up. How much are the ready-cut mylar pieces?
SWB 4x4 Collector
![]() Join Date: Jun 2001
I'd be afraid of it bubbling or peeling. I only use automotive grade vinyl, either 3M di-noc or Avery brand vinyl. I prefer Di-Noc, but its higher priced. Here was the fourth door "door panel" I had to engineer for my crew cab. I used Di-Noc and 3M primer 94 for better adhesion.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
All about them K’s
![]() Join Date: Jun 2014
Man Trevor that crew is looking more amazing every time I see your progress. Truly a work of art.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
My dad tried it years ago on a glove box, it bubbled from the heat of the cab temperature in the summer
