Old 01-25-2016, 02:12 PM   #1
nm78bronco
1976 454 heat riser tube
Hello all,
I have a 1976 GMC suburban with the 454 engine and need the factory heat riser tube (goes between the exhaust manifold stove to the snorkel of the air cleaner).
Does anyone know the GM delco part # or if it is made in the aftermarket?
nm78bronco is offline   Reply With Quote
Old 01-25-2016, 06:25 PM   #2
Matt Man
Matt Man's Avatar
Re: 1976 454 heat riser tube
This?
https://www.rockauto.com/catalog/raf...ktemplate=true
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 01-25-2016, 07:45 PM   #3
nm78bronco
Thanks a lot for your input.
The tube I need has the same function as what you mentioned, but is different.
The one I need is a rigid metal tube with a tab tack-welded to it. This tab has a hole that allows it to be attached to the cylinder head using a small bolt.
Old 01-26-2016, 01:46 AM   #4
Zane M
I have never seen a factory replacement, or an aftermarket reproduction.
I had a 78 with a similar set up and had to go with the solution presented by Matt Man(although at the time I didn't have the world at my fingertips via the internet like we do now).
Zane M is offline   Reply With Quote
Old 01-26-2016, 12:23 PM   #5
nm78bronco
Thanks for the info. I may have to see if I can find a good used one of if one off an El Camino (with a 454) would work.
Old 01-26-2016, 05:50 PM   #6
mytime
Been looking for one as well,have noticed one at the elcamino store but not sure on the fit.
mytime is offline   Reply With Quote
Old 01-26-2016, 07:58 PM   #7
nm78bronco
I bought one of these tubes for a 1980's 454 truck but it did not fit.
