Old 02-13-2016, 10:56 PM   #1
hugger6933
Anyone used a sideways 5.3?
There is an Impala SS in this weeks sale and I was just wondering if anyone had used a motor that was originally sideways. I figured the intake could be reclocked with the air inlet moved to the front. I don't know what else would be different I did note the valve cover was different but could also swap sides on that to make the oil fill on the right front corner. I have several 4L60E's laying around that could be used but am a little low on 5.3 motors [I have a couple DBW and a couple throttle ones] but the rest are 4.8's and they don't sell as good but I may use some on a couple of the trucks I have to build.
So the question is has anyone used one or have one to use and found out what all has to be done to turn it "halfway" around in the truck?
hugger6933 is offline   Reply With Quote
Old 02-13-2016, 11:42 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Anyone used a sideways 5.3?
I think the bell housing pattern is different, but I'm sure that they dont have a place to mount a starter since it mounts on the transmission on the front drive cars. I have seen a starter mounted on one but its a lot of work. They're generally not worth the effort
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-14-2016, 01:58 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Those LS4's are best saved for rear or mid engine swap projects. Not worth it for trucks and big body cars.
Hold onto it until someone with an MR2 or something along those lines wants a swap.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-14-2016, 05:56 AM   #4
Cobalt964ruf
Cobalt964ruf's Avatar
ls4 has the 60 degree v6 bellhousing. but still a good little engine. they have 243/799 heads, aluminum blocks, and flat top pistons. a guy i know put one in a old fiero and with mods it makes 412hp at the rear wheels.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 02-16-2016, 11:25 PM   #5
iowaboynca
iowaboynca's Avatar
MarioKart in real life...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
