![]() Join Date: Jul 2015
surface rust in cab shell...
So what are the options to take care of surface rust like this? This is going up into the roof on the back corner of the cab. I can reach as far as I can in there with a sander/sandpaper, but seeing how this is, it's probably going up into the roof. Suggestions?
![]() ![]() Join Date: Feb 2009
Re: surface rust in cab shell...
You can scrub some off with white vinegar and a scotch guard. Navel jelly is an option, but if you ask me, white vinegar is much better option. Sand paper as well. Then a coat of rust mort, Por15 or similar. Paint and you're good to go.
What about what you can't see, in other words, the rear window frame?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I'm doing a full resto on this, was just wondering if i should go as far as pulling the inner roof out & addressing the issue. The rear window will come out, so I'll get a good look at that.
I've never restored a vehicle but if I was restoring mine (full restoration) I'd go all out and strip it totally down and go hardcore on it. "Zero rust" would be my standard. I guess that means "media blasting" (crushed glass) for what you got there.
If you are concerned with rust between the top panels your best bet (other than separating) I think would be to spray rust convertor up in there very thoroughly and hope it got onto all surfaces. I would use one you can paint right onto and do the same with paint. Get sloppy, it doesn't matter. You can deal with the areas you see later.
Is there any reason to worry about it? I don't want to fix all the other stuff only to have this be a problem down the road.
#7 | |
![]() Join Date: Dec 2013
Posted via Mobile Device Last edited by Grumpy old man; 04-14-2016 at 08:43 AM. |
#8 | |
#9 | |
Posted via Mobile Device Last edited by Grumpy old man; 04-14-2016 at 09:38 AM. |
I'm concentrating on buying clean titled cabs / failed restorations just in anticipation of the coming huge price surge next year ,and you have to remember the 67 is a one year optioned truck .
Posted via Mobile Device |
![]() Join Date: Apr 2007
I hear what your saying Grumpy but I'm not sure I'd want to trade two good 67's for one 2017. Maybe if they gave me some money too I'd think about it.
#12 | |
Edited..wouldn't do any good.
#14 | |
