Old 10-02-2016, 06:25 PM   #1
Robznob11
Robznob11's Avatar
Need help locating air ride parts/ info
Hey guys. I need a little info here. I I'm fixing to put dom 2600 bags on my truck stock trailing arms with lower plates. No plates on top. I'm gonna run porterbuilt arms and plates up front. I need to know what size and length bolts to install the bags. Particularly on the rear. I have seen pics of bolts with a nice aluminum washer....I just need them to be strong and engage all threads top and bottom. Also with my oil pan clearance I may not be able to air out all the way in front. Where is the best place to install a bump stop and not have it damage the bag?
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 10-02-2016, 09:04 PM   #2
bbbc10
Diggin The SquareLife
Re: Need help locating air ride parts/ info
do you have inner fenders an stock crossmember?
bbbc10 is offline   Reply With Quote
Old 10-02-2016, 09:07 PM   #3
Robznob11
Robznob11's Avatar
No inner fenders, stock crossmember, relocated hood hinges...
LED TAILS
Old 10-03-2016, 01:19 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Rear bolt: measure the trailing arm, add enough length for the washer and to engage the bag to manufacturer spec'd depth. Harmonic balancer washers work well.
Front bump stop: check out how ART mounts theirs, off of the outer bolts for the upper plate, facing down.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-03-2016, 02:28 AM   #5
andrewmp6
Does your oil pan hang lower then then the lower control arms ?
Old 10-03-2016, 06:31 AM   #6
Robznob11
Robznob11's Avatar
Yes, I have made a metal cage and skid plate for protection. Eventually I will pull the motor and change the pan. But I have not wanted to go through that Hassel yet....
LED TAILS
