Old 04-10-2017, 09:19 AM   #1
rowleybd
engine stalls at idle when steering wheel is turned
So, my first weekend to have the 69 out this spring and everything went pretty good until it started to stall at stop signs, stop lights when it was idling and I turned the wheel. This truck has power steering and it feels like it is working, but the load from the pump is causing it to stall???
I let the truck set for a bit and in the driveway I started it up, good there. Idles good, belt ok on the pump. I reached in the window and turned the steering wheel......stall.
Anyone have this issue? Help Please!!!
Brian
rowleybd is offline   Reply With Quote
Old 04-10-2017, 09:55 AM   #2
old51sedan
old51sedan's Avatar
Re: engine stalls at idle when steering wheel is turned
It could be your idle speed is set too low. How far do you have to turn it before it stalls?
old51sedan is offline   Reply With Quote
Old 04-10-2017, 10:56 AM   #3
rowleybd
just a small amount of turn killed it....a couple of inches of turn maybe.
Old 04-10-2017, 05:42 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
What RPM is it idling at?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
