67 Suburban 04 Suburban Engine
I'm in the process of having the motor from the 2004 Suburban pulled and then it's going to be installed in my 67 GMC Suburban C10. Just wondering if we will be able to reuse the stock exhaust manifolds or if I need to find a set of TBSS, Envoy or Rainer exhaust manifolds?
The 04 Suburban has a 5.3 with 4L60E in it. It's all going in my 67 Sub. Thanks, Nick |
#2 | |
Re: 67 Suburban 04 Suburban Engine
I have the CPP sheetmetal mounts/perches with the dirty dingo adapters and there seems to be plenty of room to run manifolds or headers. With the older tubular mounts fitment was a major problem.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#3 | |
Thanks, Nick |
Nick- I'll post a couple pics to show clearance tonight to give you an idea.
![]() Join Date: Sep 2005
I have a 71 c10 with dirty dingo mounts on the stock 71 mounts i had to use tbss manifolds the stock manifolds wouldnt clear my enginr was a 04 silerado 4.8
I have a 82 square with 5.3 used some ebay adapters (1 inch setback ) and used 2010 camaro long tube headers
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good " ![]() |
#8 | |
There are no manifolds on it in those pics? From my experience, the truck manifolds kick out too much at the rear and will hit the frame. Maybe if you shove the engine all the way back to the firewall they won't, but I wanted the engine in the factory location.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Thanks for the pics and the info guys. I'm hoping I can get the factory manifolds to work if not I'll look for a set of TBSS or similar stock manifolds.
I did test fit with the factory manifolds (just didn't take pictures since I am going to run headers). With these sheetmetal perches and the dirty dingo adapters there was a ton of room on both sides. The only thing I have to do is relocate the a/c compressor up top.
The 2010 Camaro manifolds fit great. I actually used the down pipes and dual cats on my suburban. I also used the sliders from dirty dingo and set my engine almost all the way foreward to allow the stock ls fan and original 1968 shroud to be used
There are some.pitcures in my build link
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Oct 2012
Just for thought, if there is some interference, you can always notch the frame. It's just an idea.
#14 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 | |
thanks in advance. -Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
#16 | |
(You can minimize the abuse from those morons at CPP by buying from summit)
#17 | |
![]() ![]() ![]() I think i may have reacted to your post a little to quickly. I have an 86, these SHOULD fit, right? I have always been under the impression that the cross members and the motor mounts are pretty interchangeable between the 67-72 and the 73-87/91 well more specifically 63-87/91, like if you wanted to put disk brakes on your old drum truck just roll all the parts from under a square under your drum and be done, direct bolt up... so i assume, well i am asking, if these fit the squares as well as they fit the 67-72? make sense? or do ya know? I may just go ahead and order them just to find out for myself if no one knows for sure. i emailed CPP last night, but after your comment above, i dont expect to hear from them about specifics. ![]() -thanks in advance - Izzy
#18 | |
#19 |
Active Member
![]() Join Date: Aug 2004
The stock manifold needs slight mod to fit. Using a torch and crescent wrench to make frame mod. here's a video of a swap.
https://www.powerblocktv.com/episode...p#.WIJEHk0zWUk First question would be are you going to run A/C? if so then read this thread its a later year but same concept http://67-72chevytrucks.com/vboard/s...d.php?t=413855 By moving the stock frame mounting bracket back an inch or so the A/C compressor will fit, otherwise you need to by the adapters to mount the compressor on top of the engine. The 67 should have pre drilled holes to move the mount back, but it's more like 2+ inches, so I might need to just drill some holes. I have not dropped the motor in yet to see just how it fits. Between the weather and other things needing attention. Maybe next weekend. Last edited by binford; 01-20-2017 at 01:36 PM. |
#20 | |
I think the whole thing is not going to be real pretty but I am building the LS for function over form.
#21 |
Does anyone have a part number of the actually motor mount that they used with the CPP perches and Dirty Dingo sliders? We were trying to use an older Corvette style mount and it would not fit at all.
Thanks, Nick |
#22 |
I don't have a part number but you can search by year 1967-72 small block mounts worked fine with my DD sliders. You need to make sure you have small block engine stands not big block or 6 cylinder.
#23 | |
https://www.summitracing.com/parts/clp-6372mp-sm |
#24 |
The CPP sliders look like a diffirent mount than 67-72 trucks the trucks use one 7/16 bolt in the center. The CPP mounts look to use the long bolt thru the mount and frame stand
. Sorry I can give you a solid answer on what mount to use.
#25 | |
https://www.summitracing.com/parts/e...114r/overview/ |
