Old 03-28-2017, 09:04 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
Original Upper Radiator Pipes
I was wondering if anyone has any info on upper radiator pipes.
The black was removed from our 66 chevy with 283.
The others were removed from 63-66 but might not be correct.
Any information on the different pipes would be appreciated.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 03-29-2017, 09:53 AM   #2
Robert Haas
Re: Original Upper Radiator Pipes
Those look like they were made with a muffler shop bender.
Robert Haas is offline   Reply With Quote
Old 03-29-2017, 10:32 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I'm thinking back in the day the term "mandrel bent" wasn't invented yet.
Old 03-29-2017, 11:21 AM   #4
60-66
60-66's Avatar
The black one is correct 1963-1966 Part number 3826373 with 283 series 10-30 ( Exc A.I.R. ). The two short ones ( I think ? ) are part number 3889196 which is 1966 283 WITH A.I.R. . Theres one more specific to 1965 and 1966 327 10-30 series 3868549 . A.I.R. being Air Injection Reactor or Smog pump , not AIR Conditioning. I don't think I have that one but all 3 have different bends and lengths. Im thinking the 65 66 327 has to do with the 4 core radiator ? I'll see if I can post a picture of all three later.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-29-2017, 11:26 AM   #5
60-66
60-66's Avatar
Didnt you part out a C60 or big truck ? That could be another one with a different bend. None of the numbers I posted are for medium or larger trucks
Old 03-29-2017, 11:45 AM   #6
VictoriaHardware
VictoriaHardware's Avatar
Are the header tanks for a 4-core different than a 3?
VictoriaHardware is offline   Reply With Quote
Old 03-29-2017, 11:54 AM   #7
60-66
60-66's Avatar
Just that its thicker , might also have to do with the raised water neck or a combination of both
Old 03-29-2017, 12:43 PM   #8
Classic v6 GMC's
We did have a 65 with 327 so that might be one of the short ones.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-29-2017, 12:59 PM   #9
Classic v6 GMC's
We did have a c60 so maybe one of them is from it.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 03-29-2017, 01:35 PM   #10
65chevysub
65chevysub's Avatar
I have an aftermarket one for my 283 but have to have it modified as it is right up against the radiator inlet so can't get the rubber hose on it. Since no one makes the pre formed rubber hoses for these engines, I'm going to put the metal one on.
65chevysub is offline   Reply With Quote
Old 03-29-2017, 07:36 PM   #11
60-66
60-66's Avatar
Are those two short ones exactly the same ? If we could get Yelmer to chime in Im sure he has some 327 info on these.
Old 03-29-2017, 09:32 PM   #12
Classic v6 GMC's
No, the top pipe in the first picture has a bigger end on the left side and the bends are a little different.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
