Old 05-22-2017, 04:37 PM   #1
Chevystep
66 headlight bucket attachments
A couple of picts of the headlight bucket/holder/adjuster into the grill, near as I can remember, these were held in with 4 rivets. Assembly manual has a rivet holding this together. Seems like these being in there firm is imperative as this is the main attachment point for the grill to the front fascia behind it, would bolts and washers be a better idea than a good steel pop rivet?I doubt I'll use a blind rivet and peen it over....
Chevystep is offline   Reply With Quote
Old 05-22-2017, 04:42 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 headlight bucket attachments
I will be using stainless #10 screws with lock nuts when I assemble mine.
But the assembly attaches to the truck from inside the front wheel well with fasteners as I believe you have indicated.
Old 05-22-2017, 04:59 PM   #3
Chevystep
That's kind of where I was heading to as well with the #10's, but I swear these things were just lightly riveted in when I took it apart. One side of the grill only had 3 holes drilled for the attachment points from the factory...so it always had one wonky headlight that never quite stayed adjusted...
Old 05-22-2017, 05:01 PM   #4
The Rocknrod
Moderator
Yes they were riveted.
Old 05-22-2017, 06:28 PM   #5
Lugnutz65
Lugnutz65's Avatar
Some pics from my files. My 1965 grill had 4 rivets per side.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 05-22-2017, 08:31 PM   #6
Chevystep
Oh man! That's the money picture! Also shows the 2 interior tabs are one above/one below the grill piece! Big time thanks!
Old 05-23-2017, 09:51 AM   #7
aggie91
I'm just glad to be here!
aggie91's Avatar
I did mine with #10 bolts/washers/nuts nearly 25 years ago. Never had any issues with mine. That picture of the OE rivets is worth its wait and is shows how it goes together. You can't get the bracket in the grill UNDER all 4 tabs. One has to be under the bracket and that is the factory way.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
