Old 07-02-2017, 01:05 AM   #1
tkeduk8r
tkeduk8r's Avatar
250-292 Intake and Exhaust manifolds restored
Have your choice of a pair of intake and exhaust manifolds i prepped to use on my 250 build, but stumbled into a set of Clifford intake and headers and no longer need these.
First is my first/original set that I had a machine shop bake and shot peen for me. Castings are real nice and will work great in a stock application. $30 plus shipping to lower 48.
Second is a set I found that has the larger 2.5" exhaust manifold from a 292 in a medium duty truck. This set I again paid to have baked and shotpeened. I then painted the intake with ceramic high temp paint and the exhaust manifold was coated in Eastwood's high temp cast coating. I also installed new studs and a heat separator gasket. Had this set installed on the finished engine before the Clifford set up kind of fell into my lap. If I had to do it over again, I would have just stayed with this setup and run an adapter for a Rochester 2Jet carb. This set I need $175 plus shipping, but could swap on with zero mods and your up and running.
First Ill take it.
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
