Old 04-24-2018, 11:41 PM   #1
krue
Designated A-hole!
krue's Avatar
While it's out
What do I need to do on my 6.0l. Figure on gaskets on valve covers and oil pan, intake and exhaust gaskets. What else tends to leak on these? Rear main and cover? What about oil pump? Near as I can tell the engine has at least 133k miles on it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 04-25-2018, 12:03 AM   #2
suburban99
suburban99's Avatar
Re: While it's out
I did the valve covers and bolt hole grommets, oil pan gasket, oil pump, rear main, front main, intake gaskets and o rings for injectors..and water pump as I drilled and tapped it for the stock 350 temp sender.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 04-25-2018, 12:14 AM   #3
mongocanfly
mongocanfly's Avatar
Re: While it's out
If you change the oil pump keep in mind it has to be shimmed....'
mine didn't have any leaks when I installed it so I didnt touch anything....but changing the easy stuff would be a good piece of mind...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-25-2018, 01:50 AM   #4
krue
Designated A-hole!
krue's Avatar
Re: While it's out
May just go with that approach, mine isn't leaking. But it's a lot easier to do it now than after I install it.
www.daveramsey.com
Old 04-25-2018, 10:35 AM   #5
Ghost's68
Ghost's68's Avatar
Re: While it's out
Lifters and lifter trays. Pretty cheap! What everyone else has said
Ghost's68 is offline   Reply With Quote
Old 04-25-2018, 01:44 PM   #6
Notch1988
Notch1988's Avatar
Re: While it's out
I guess it depends on what you want to do. For me, I bought a cam, valve springs, oil pump, CTSV oil pan, lifters, lifter trays, head gaskets, head bolts, knock sensors, cam bolts, gaskets for everything I'm taking apart. Basically complete teardown to shortblock, leaving main and rod caps alone.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 04-25-2018, 04:32 PM   #7
truckdude239
truckdude239's Avatar
Re: While it's out
I just did my tahoe i did vavle covers valley pan intake, rear main seal and the cover water pump and let it ride
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
