![]() ![]() Join Date: Feb 2009
What hardware used engine stand bolts?
C-10 402
I just built an engine stand and see the bolt sleeves used to mount the block to the stand are 3/4" ID. Meanwhile the block uses 3/8" bolts, leaving a lot of play in those sleeves. Is this a problem in your mind? Any ideas? Either way I'll use grade 8 bolts. For what it's worth, the bolt holes in the block are 1" deep. Thanks
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Dec 2013
Re: What hardware used engine stand bolts?
No problem, grade 8 3/8 are what screw into the block.
![]() to make it easy pull the pin and bolt the bracket to the block to get it centered and even then raise the engine up to insert the bracket into the stand and lower the whole mess slowly to the floor . |
#3 | |
You lost me on lower the engine to the floor business, but I think you mean lower the block & bracket into the stand. Unfortunately I take things awfully literal ![]() Short have mentioned, hopefully I'm through with this nonsense this week. My son and I are going to tackle it, so I can start the build already ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-14-2018 at 09:15 PM. |
![]() Join Date: Jan 2001
Use washers under the heads of the bolts and snug them down tight. They won't move on you.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Sounds like a plan. Thank you.
