Old 07-26-2010, 10:45 PM   #1
irishman999
irishman999's Avatar
Location of oil pressure sending unit.
Im think i saw the oil pressure sending unit on the passenger side of the block under the exhaust manifold. I just need to be sure.
irishman999 is offline   Reply With Quote
Old 07-26-2010, 10:52 PM   #2
f.monroe
f.monroe's Avatar
Re: Location of oil pressure sending unit.
That is probably a knock sensor on the pass side . The oil pressure switch is usually right at the back of the intake ,behind the distributor on he driver side, or on the drivers side towards the rear of the block.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-26-2010, 11:20 PM   #3
3r!c84
Badass
3r!c84's Avatar
Frank
what is a knock sensor and what do it do?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-26-2010, 11:25 PM   #4
f.monroe
f.monroe's Avatar
A Knock Sensor detects detonation and relays the info so that the comp can retard the timing a little .
Frank
Old 07-26-2010, 11:34 PM   #5
irishman999
Sorry, its a 305 i forgot to mention that. I had no idea this thing had a knock sensor, The wire melted onto the exhaust manifold whats this going to cause? The reason i ask about the oil pressure sending unit is i bought a aftermarket gauge set and have to install one of those plastic hardlines, it sounds like this is going to be a pain, is there clearance for fittings and all that?
Old 07-26-2010, 10:53 PM   #6
flamingbig10
6.0 powered square
flamingbig10's Avatar
what motor if it a small block its next to distributor on the driver side
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-26-2010, 11:38 PM   #7
WigglesTheHoly
IT Guy/ Father/ Chevy lover
WigglesTheHoly's Avatar
just put one on my 79 Saturday its located on by the distributor on the drivers side.
78 Chevy (Pictures) SOLD
79 Chevy LWB (pasture)
83 Chevy LWB (crushed rusted beyond repair)
02 TrailBlazer SOLD
03 VW Passat wagonSOLD
95 extended cab silveradoSOLD (still in family)
05 Crew Cab Silverado 5.3 (The Turd)
WTB: 66 El camino
Technology Specialist aspiring to be a gear head.
WigglesTheHoly is offline   Reply With Quote
Old 07-26-2010, 11:54 PM   #8
irishman999
Awesome thanks for the info, thats why i love this site. Okay the million dollar question... The last guage i have is the voltometer, how do i wire this in to show my volts?
Old 07-27-2010, 12:00 AM   #9
flamingbig10
6.0 powered square
a volt gauge just needs two wires a positive switched and a ground, are using a factory gauge or after market
Aaron
Old 07-27-2010, 12:12 AM   #10
irishman999
Its an aftermarket gauge. My truck came with the idiot lights so im phasing those out right quick.
Old 07-27-2010, 10:11 AM   #11
pseudopimp
pseudopimp's Avatar
i have an aftermarket guage on mine if you want to stop by and see how it is wired up just give me a call.
84 Scottsdale LWB K10
Rooting against the cowboys is almost as fun as rooting for the GIANTS!
pseudopimp is offline   Reply With Quote
Old 07-27-2010, 11:26 AM   #12
nbpro
305 Location of oil pressure sending unit.
The two locations it could be are
1. Top rear of engine next to distributor
2. Bottom drivers side of engine above the oil filter.
The second option is more likely as it was moved to this location on most vehicles in the early to mid 80s
nbpro is offline   Reply With Quote
Old 07-27-2010, 04:03 PM   #13
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My '86 305 was by the distributor.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-10-2018, 12:25 AM   #14
nascarmikeb
I have an 87 sierra classic, original engine was 305 TBI,
I have pulled it and replaced w/ pre-1980 4bolt main 350. Truck has a gauge not idiot light. I have the location behind the distributor and I have the one just above the oil filter. I want to remove the plug from the above the oil filter, it is very TIGHT!!! what would be best way to remove this plug? I dont have a torch for heat.
My '87 wiring harness for the gauge is a single tan wire on the driver side that plugs into the single spade clip on the sender above the oil filter. So I need to really remove this plug. I just dont want to break it off. I sprayed lubricant, hopefully it will loosen up.
Mike
nascarmikeb is offline   Reply With Quote
Old 05-10-2018, 12:31 AM   #15
mongocanfly
mongocanfly's Avatar
I'd just put the sender behind the distributor....no issues.....if the plug is that tight I'd leave it alone...without the proper tools
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 07-27-2010, 04:17 PM   #16
westofb
I really hate wet sanding!
westofb's Avatar
Isn't there a threaded plug near the top of the timing cover in the front of the block that could be removed and used for an aftermarket oil pressure gauge? Not sure myself, just thinking aloud. Most SBC have the sending unit/ oil pressure gauge line are located in the top of the block behind the rear of the intake manifold by the distributor on the drivers side of the engine block.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 07-27-2010, 05:49 PM   #17
nbpro
my 81 gmc Bottom drivers side of engine above the oil filter.
Old 07-27-2010, 07:12 PM   #18
irishman999
I found the one on top, I will try threading my fittings into that one, thanks for the help guys!
pseudopimp- Im still up here in Ruidoso but within the next couple days i will be going through Cruces, Pm your phone number to me since i dont know my cell number haha.
