front crossmember-pre runner bumber Build
Hay everyone id like to share my most recent update to my truck
this idea started out of the blue and a piece of 12in x 3/8in flat plate. it may not be what you like or built the way you woud do it but its 100% my truck and my idea and i think it turned out ok. whole thing is bolt on using factory frame holes (+ some holes) with 1/2in and 5/8ths grade 8 bolts and the bumber can be removed from crossmember. tubing is 1 1/2in .120 DOM only tools used were a welder and and angle grider. hope you enjoy. SO IT STARTS- FRAME WIDTH X12in FLAT PLATE SCORDED AND HAND BENT, SEEMS WELDED UP GROUND DOWN AND SMOOTHED. (MY IDEA WAS A CROSSMEMBER THAT WOULD WRAP AROUND FRONT OF TRUCK FRAME. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() CROSSMEMBER ALL DONE ![]() ![]() ![]() STARING TUBE BUMBER DESIGN-ANGLE OF 1970 GMC GRILL ![]() MATCHING TUBE ANGLE WITH GRILL ANGLE ![]() THE 2 (OUTER ANGLES) LINE UP WITH INSIDE OF HEADLIGHT BUCKETS ![]() 1/4in PLATE USED FOR FRAME TIE INS ![]() HUGS THE FRAME ![]() ![]() ![]() ![]() NOT ME :-) ![]() DESIGNED IT TO LINE UP WITH BOTTOM OF GRILL ![]() ALL DONE ![]()
1970 2wd ![]() ![]() ![]() |
Re: front crossmember-pre runner bumber Build
Current project. Tubular upper control arms. Built not baught
Looks great!
72 C10 lwb fleetside -stock 350/350 combo |
Nice fab. I will be watching for updates.
Update. I fabbbed some rectangular tubing upper arms. To be used with uniballs instead of ball joints.
Going to modify lower stock arms and will run a uniball set up there to. Current project. Fabbing lifted spindles. Then front/rear disc brakes -hydroboost setup. Already baught - 40x13.50x17 toyo mt. / real beadlocks - Atx slabs
Are you going to run the truck in the desert or is this more for looks?
Nice work. I'm liking your plan. You'll be having a true custom concept/build. Nice!
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks nice, I'm in to see more
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Thanks everyone for the positivity. Some think its impossible or I dont have enough resources to build my idea.
