Old 11-24-2003, 06:28 PM   #1
lock
Insert funny comment.
lock's Avatar
Air tank mounting locations
Im fairly new to the air ride suspension stuff. Is it possible to have air bags for front and rear and mount all the equipment under the bed? I do plan on relocating my gas tank to the frame as well... just wondering if there is room for an air ride suspension while im planning my truck build up.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 11-24-2003, 11:29 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Mines not a 67-72, it's a 77 but there shouldn't be that much difference back there. Here's what was done on mine....
Tank shot-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-24-2003, 11:30 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Compressor shot-
Old 11-24-2003, 11:30 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Big Red valves-
Old 11-25-2003, 12:24 AM   #5
lock
lock's Avatar
Hmm from seeing your frame shots, Im guessing the answer is no if I plan on relocating the gas tank.
Old 11-25-2003, 01:34 AM   #6
Shane
Shane's Avatar
thats exactly what I was thinking ... I would love to put my tanks and compressors there ... but there is already a poly Blazer tank there.
Shane is offline   Reply With Quote
Old 11-25-2003, 03:23 AM   #7
valley 67
valley 67's Avatar
I HAVE 67 AND 5 GAL TANK IT FIT ALONG FRAME RAIL UNDER CAB DRILLED AND WELDED NUTS TO TANKS LEGS
valley 67 is offline   Reply With Quote
Old 11-25-2003, 11:17 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah, if your putting a Blazer tank in the rear, it won't work like mine. Personally I woudn't put my gas tank back there. The main reason we removed the spare tire was it hung down too low. I would think the gas tank would too.
We mounted the air tanks on my Blazer outside the frame in the rear. They plan to raise the rear floor, and make a smaller gas tank to prevent it from dragging...
Here it is now...
Articles-
"Refining Sierra"
Old 11-25-2003, 11:18 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Another view-
Old 11-25-2003, 11:19 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
It looks like valley 67 has you answer if your set on a tank in the rear...
Old 11-25-2003, 01:40 PM   #11
grnddwn
belly dragger
grnddwn's Avatar
I put mine in the back on either side of the tank like N2TRUX
grnddwn is offline   Reply With Quote
Old 11-25-2003, 03:13 PM   #12
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
i plan on relocating mine, but i want to wait until I upgrade to a 12 gallon tank and engine driven compressor. Right now i've got to listen to my 6 gallon and my compressor mounted behind the seat.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 11-26-2003, 12:08 AM   #13
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Anyone ever thought of boxing in your frame rails and using them for you air tanks. Put a few bungs in and you set.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-26-2003, 12:16 AM   #14
grnddwn
belly dragger
grnddwn's Avatar
Seen it done its alot of work though
Old 11-26-2003, 12:30 AM   #15
Shane
Shane's Avatar
personally, I don't want it in the cab with me ... but that's something the '73 & up trucks don't have to worry about either.
Old 11-26-2003, 01:29 AM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
I can understand you not wanting it in the cab. I wouldn't want the either. I was just commenting on the rear seems like a bad place to put it too.
I guess the floor on the 67-72 cab won't allow you enough space to mount it under the bed/cab like the 73-87's do. Is there room to put a custom built tank along the frame like that?
Old 11-26-2003, 01:31 AM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, I have. If there is enough room, I may do this on my Blazer...
Old 11-26-2003, 02:26 AM   #18
valley 67
valley 67's Avatar
MY TANK MOUNTED UNDER CAB NO MODS AND STOCK CAB MOUNTS..
Old 11-26-2003, 11:35 PM   #19
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
I was thinking of mounting mine inside the "rocker box" on my 70 Jimmy. Probably won't because so the work involved.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 11-27-2003, 12:19 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Well that answers that question. Got Pics?
Old 11-27-2003, 12:24 AM   #21
valley 67
valley 67's Avatar
ILL TAKE PICS THIS WEEKEND
Old 11-29-2003, 12:21 AM   #22
valley 67
valley 67's Avatar
1
Old 11-29-2003, 12:22 AM   #23
valley 67
valley 67's Avatar
2
Old 11-29-2003, 12:23 AM   #24
grnddwn
belly dragger
grnddwn's Avatar
Will it be in the way of your exhaust?
Old 11-29-2003, 12:23 AM   #25
valley 67
valley 67's Avatar
3
