Old 05-24-2019, 05:23 PM   #1
Starwood
Starwood's Avatar
Rear Shock Relocate Options?
So, I've only had this truck for a short time and I'm uncovering the little surprises 1 by 1 by 1...
The latest issue is the rear suspension.
I knew it was riding rigid so I went down to the local shop to talk options. When we got underneath - I was blown away when I saw the missing chunk in the pics below. It's lowered but not slammed, and I will be replacing shocks all around for sure.
I have a guy who can weld a slat on there for me, but I'm asking you Fellas what you would do if it was your truck.
Any thoughts/comments would be appreciated.
Thanks Fellas,
-=RR=-
Starwood is offline   Reply With Quote
Old 05-24-2019, 07:00 PM   #2
Starwood
Starwood's Avatar
Re: Rear Shock Relocate Options?
I’m thinking this might be my ticket:
http://nolimit.net/products#!/Droppe...tegory=6157547
Unless I’m missing something - this might be the way to go to avoid unnecessary mods to current leaf spring setup.
Any thoughts on these folks and their products?
Old 05-24-2019, 07:21 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
With that shock angle, you literally have no shocks.
I like their (no Limit) rear sway bar set up also. I have a CPP Unit now but am planning on swapping it out for theirs.
However since your lowered you might consider the CPP rear cross member - http://67-72chevytrucks.com/vboard/s...d.php?t=659584
It allows my rear end to bottom out in the C-notch before the third member touches the cross member.
Old 05-24-2019, 08:15 PM   #4
Starwood
Starwood's Avatar
Truth on the shock angle for sure.
I'm looking at all options - and appreciate the response.
I'll check it out.
Thx again.
Old 05-24-2019, 08:23 PM   #5
PGSigns
PGSigns's Avatar
I have a 65 GMC frame out back and can get you pictures tomorrow of what the factory brackets looked like. That may give you an idea on a way to proceed. Not sure if its the picture angle but the drive shaft angle looks a bit steep.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
