This ole girl followed me home
55 GMC has some rust but not bad. Runs but has blow by. Just picked up the bed yesterday has a couple of small dents but no rust. Not bad for 800
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: This ole girl followed me home
Nice find....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
![]() Join Date: Oct 2007
Nice find ,,,is it a original dually ? your in Idaho but way north of me . like to see this in person.. keep in touch with your improvements with this diamond in the rough ..
When you learn a thing a day you store up smart. |
Can't wait to see that cleaned up, nice score.
![]() Join Date: Dec 2009
I like it.
Great deal. .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jan 2001
She's a beauty. Congratulations.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Nice. I would have snapped that up in a second for 800
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
Looks solid
The rear is not factory. The winch is home make but the guy that built it sure used his noodle. The truck hasn't been licensed since 1975. The guy I got it from only used it a couple of times. For the time being I have to let it sit as winter is around the corner and I have a lot of wood to get in.
Question for all you wenches. I'm looking for a rear end for this thing. What would be a good rear? I'd like to be able to do atlease 65 with it. It's a 3/4 ton. |
Are you asking about ratio or specific rear end units? I like a 3.73 rear as a good general-purpose rear for a truck. It will get you to freeway speeds easily enough.
I need a complete rear. I was wondering if there was a specific year truck I could the rear from?
A 14 bolt full-floating rear axle would be your best
choice IMO. Ratio choices :3.21, 3.42, 3.73, 4.10, 4.56, 4.88, 5.13, and 5.38 https://en.wikipedia.org/wiki/10.5%2...t_Differential .
I would also recommend a newer model 14 bolt FF.
^^I agree^^
One change that occurred in the second design was that on some models the brake drum could be removed without having to remove the hub and axle shaft .
#15 |
Guys, these 14 bolt ff rear ends that you are talking about. Are 2 wheel drive and 4 wheel drive rear ends the same? And it must be 8 lugs.
I've always been a motorcycle guy this is all new to me. I have lots of dumb questions. Thanks |
#16 |
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#17 |
![]() Join Date: Jul 2015
Ask a dumb question, feel dumb for a minute, don't ask a dumb question be dumb forever....
Looks like a nice score!!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#18 |
![]() Join Date: Nov 2004
I was kinda hoping for a bad wife joke, but this is much better. Cool truck. Definitely don't see many 55-59 GMCs.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#19 | |
Here some of the specs I found with the differences. Spring perch will probably be the main issue for you.(maybe or Maybe not) 14 Bolt Axle Dimensions WMS to WMS width '73-'91 Axle tube diameter Axle tube thickness Hub type Driver axle shaft length Pass. axle shaft length Wheel stud threads Brake type Pinion centered SRW 67.5" '89-'00 3.375" 0.5" Outboard 37.625" 31.625" 9/16"-18 Drum Yes SRW 65" '00-07 3.375" 0.5" Outboard 37.625" 31.625" M14-1.5 Drum Yes SRW 68" 3.375" 0.5" Outboard 37.625" 31.625" M14-1.5 Disc Yes DRW 72" 3.5" 0.5" Inboard 9/16"-18 Drum Yes C&C DRW 63.5" 3.5" 0.5" Inboard 37.625" 31.625" 9/16"-18 Drum Yes SRW Van 70" 3.5" 0.5" Outboard 39.375" 33.375" 9/16"-18 Drum Yes 14 Bolt Axle Spring Perch Width Axle Spring perch spacing 3/4 ton 14 bolt 42.5" 1 ton 14 bolt 40.5" Info came from this link: https://www.roundforge.com/articles/...rw-drw-and-cc/ .
#20 |
I found that this truck is worthy of a back yard restoration. The rust is not bad but needs some love. The question I have is where the front motor mounts are there two pieces of channel welded to the frame. Is this right or Mickey and goofy working on it before I got it. Thanks
#21 |
those mounts look like they were used to install an early style engine with the front motor mounts - the ones that look like a bolt with rubber washers.
Not being really familiar with this era truck, maybe some one can clarify. some one may have done an engine transplant.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
#22 |
Here is a better pic.
#23 |
![]() Join Date: Jul 2007
I'm thinking that the mounts show that someone did a quick and nasty engine change in it. That doesn't happen to be a 235 or 261 rather than a GMC engine?
You are going to have to watch the axle width on the back real close to keep the tires under the fenders. I'd check the rear axle to make sure that they didn't just adapt it for the dual rear wheels and leave the 3/4 ton axle. My buddy did that a time or two but he is in a nursing home with dementia and isn't able to tell me how he did it. A real dual wheel rear axle is usually a bit narrower than a single wheel axle. That would let you remove the duals and fit the bed and fenders to it while hunting down the right axle with road gears. That truck looks pretty good for having a wrecker boom on it. I've seen a few with those home made booms used for yard dogs in wrecking yards that were beat to death but that one must have had a specific task to do in it's life.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 06-25-2020 at 11:52 AM. |
#24 | |
![]() Join Date: Mar 2012
I'd love to see more pictures of the boom and winch. I see a manual crank... is it also powered by PTO? There's a hydraulic brake assembly to slow or stop it... Is that park brake lever connected to a master cylinder? very cool stuff. For the axle a Dana 60 or 14 bolt corporate axles are both good choices. You may want to look for axles from a cutaway van chassis instead of a truck. I believe they are narrower. Also, the 2003 and newer G vans have a bolt-on spacer that allows a single wheel front end to use wheels for the dually. If the dimensions work out you would be able to run only one type wheel. ![]() These are some axle dimensions for a 98-2002 ish van. . Last edited by 1project2many; 06-25-2020 at 03:36 PM. |
#25 |
58 pan - you're lucky you are in Sand Point. There is a guy down the road in Athol that deals in old Chevy truck parts. he's posted on craigslist - Spokane. if you cant find his number, I may still have it.
Looks like a fun project.
