Old 05-13-2021, 09:13 PM   #1
67C10Step
67C10Step's Avatar
Exhaust Question
Trying to decide what to do on my exhaust. Stock 283 with stock manifolds. I don’t have interest in going to headers. Is there a kit out there that fits stock manifolds that I could install or best to just take it to a shop and let them do it?
If I do it myself I’ll tackle it before I put the bed back on. I was thinking of doing something a little different in doing dual exhaust but both exit on one side.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 05-15-2021, 02:12 AM   #2
Boog
laying low
Boog's Avatar
Re: Exhaust Question
Summit, LMC and multiple others offer stock type exhaust kits. I bought a dual kit from LMC made by Hearthrob if I remember right. I tweaked the down pipes a bit to tuck them in closer to the frame rails, installed some red Walker gpacks then angled the pipes out at a 45* under the steps. Your idea of duals out the same side will make it necessary to see a local muffler shop to custom bend you a set.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-17-2021, 12:04 PM   #3
67C10Step
67C10Step's Avatar
Thanks, Jim. I’m still tossing ideas around in my head. I don’t want anything remotely loud, but a little rumble would be nice.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 05-17-2021, 12:26 PM   #4
Mac93
Mac93's Avatar
I accidentally posted twice and cannot delete this duplicate..
Mac93 is offline   Reply With Quote
Old 05-17-2021, 12:29 PM   #5
Mac93
Mac93's Avatar
https://www.summitracing.com
I cannot post full link for some reason. Its the Hooker Headers 16621HKR- hooker competition Manifold back system
Kit I used a few hears ago. Bolted up no problem and had the necessary hardware. Inevitably some minor tweaking will be required to an extent( I needed to cut a little out of the Long section to make the axle hump line up).. Took a couple hours start to finish. Just need to buy Mufflers of your choice.
Old 05-17-2021, 07:22 PM   #6
jimijam00
Take it to a shop and tell them exactly what you want. Dual exhaust is overkill on that truck. You can run the manifolds into a Y, then single back to a single muff with dual outs, then two pipes coming out the side (before or after the wheel) with tips on them.
Similar to this.
jimijam00 is offline   Reply With Quote
Old 05-19-2021, 02:24 PM   #7
MikeB
MikeB's Avatar
Heartthrob kit with side exit tailpipes:
http://www.heartthrobexhaust.com/4143sk.PDF
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-19-2021, 03:51 PM   #8
MARKDTN
Exhaust is a pain, especially without a lift. I would take it to an exhaust shop and let them deal with it. They will be done before you could get started-and if your kit doesn't fit and needs a bend you are stuck while if theirs doesn't fit they just use the machine and tweak it. I have tried twice to buy kits for cars and both times didn't quite fit and ended up at an exhaust shop anyway letting them fix it for more total cost than they would have done the job for in the first place. Exhaust is a job for the people with a bender and a lift.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-19-2021, 08:34 PM   #9
jimijam00
The diagram in the kit you linked does NOT have duals out the same side. Did you post the wrong link?
Old 05-20-2021, 10:54 AM   #10
MikeB
MikeB's Avatar
MARKDTN is right, unless you or a buddy know how to weld. But I sure do like the kits' mandrel bends vs. some of the horrible crush bends made by muffler shops. A shop would have to use 2-1/2" pipes to (hopefully) achieve the same flow as a mandrel bent 2-1/4" pipe.
Left photo below is an example of a crush bend. Both are 2-1/4" pipes. The bend looks like is has the flow of a 2" pipe or worse!
Right photo (of a different truck) shows mandrel-bent pipes in a HeartThrob kit that I pieced together to fit 97 manifolds.
Mike
Old 05-20-2021, 10:55 AM   #11
MikeB
MikeB's Avatar
Guess I'm a bad speed reader! I thought Boog said "sides", as in exiting both sides.
Mike
Old 05-20-2021, 05:15 PM   #12
cab4word67
cab4word67's Avatar
Does anyone have recommendations on Mid length headers that will work with SBC D port heads.
cab4word67 is offline   Reply With Quote
