Old 01-22-2022, 01:18 PM   #1
A.Delaney
A.Delaney's Avatar
Help with Frame ID
This frame has a cab off a 66 but the owner thought maybe the frame is a 67-72. I figured the professionals here would know what it is.
72 Chevy C20
86 Silverado Shortbed
A.Delaney is offline   Reply With Quote
Old 01-22-2022, 02:29 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Help with Frame ID
A good picture of the bumper would help.
From that picture that appears to be a 67-70 bumper.
From research of other threads.
That it is probably a 1970 frame from St. Louis.
Because partial VIN's are stamped on the frame.
The first digit on the frame would be the 5th digit in the VIN of the truck.
5th digit is last number of the year and 6th digit is Assembly plant.
Link: https://gmcpauls.com/67-72_chevy.htm
The early bird gets the worm,
84 Chevy K-20
Old 01-22-2022, 03:42 PM   #3
A.Delaney
A.Delaney's Avatar
Okay thanks! I was looking in other threads but I couldn’t figure out how the frame number meshed into the VIN. I’ll see if I can get a picture of the bumper.
72 Chevy C20
Old 01-22-2022, 04:21 PM   #4
A.Delaney
A.Delaney's Avatar
Also is it possible that the 0 could be 1960?
72 Chevy C20
Old 01-22-2022, 04:29 PM   #5
Getter-Done
I think the 60-62 frames look like this,
From what I have read on here the front bumpers won't interchange from the 60-66 to a 67-70 frame.
84 Chevy K-20
Old 01-22-2022, 05:14 PM   #6
A.Delaney
A.Delaney's Avatar
Okay thanks! Here is the front bumper.
72 Chevy C20
Old 01-22-2022, 05:35 PM   #7
Getter-Done
With pictures from the forum.
Here are the60-66 bumpers they have different bolt spacing also.
84 Chevy K-20
Old 01-22-2022, 06:28 PM   #8
A.Delaney
A.Delaney's Avatar
Ya that’s certainly not the same bumper. The frame must be a 70 then. Thanks for the help.
72 Chevy C20
Old 01-23-2022, 12:39 PM   #9
Bigdav160
Bigdav160's Avatar
I see disc brakes
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-23-2022, 01:10 PM   #10
A.Delaney
A.Delaney's Avatar
I believe the front is a d44. Maybe converted or out of a newer truck?
72 Chevy C20
Old 01-23-2022, 05:42 PM   #11
57taskforce
All about them K’s
57taskforce's Avatar
Definitely a 70 4x4 frame. I’m guessing K10 long bed. That’s a th350/205, looks like it’s got the ‘70 only automatic tranny transfer case shifter still there as well. Also looks like the transfer case crossmember is still riveted. Front axle had to have been swapped at some point but still a great find if the rust isn’t too bad, which it doesn’t appear to be.
Tyler
57taskforce is online now   Reply With Quote
Old 01-23-2022, 06:35 PM   #12
A.Delaney
A.Delaney's Avatar
Fantastic thank you. The block casting is 330817. Looks like it’s a 400 small block. Did these trucks come with a 400sbc?
72 Chevy C20
Old 01-23-2022, 07:20 PM   #13
57taskforce
All about them K’s
No sir, no big blocks or 400 small blocks for the 4x4 trucks. The 350 was the biggest V8 you could get in a 67-72 4x4.
That should be a 400 casting. Not a bad score at all if it’s still good.
Tyler
Old 01-23-2022, 07:58 PM   #14
A.Delaney
A.Delaney's Avatar
Okay thank you. Time to negotiate.
72 Chevy C20
