will 265 75 16s fit on my truck?
i've got 245 75 16s on it now, and i know where i can get the 265s for $10 ea (used but in good condition) will they fit on my truck the way it sits right now (stock no BL, non-cranked bars)
Sure.......S/S
I dont see why not. I'm sure you have plenty of clearance and I highly doubt they will rub, being that they are only 1" difference.
The 245's are 30.5" tall and the 265's are 31.6" tall |
Project92 SWB stepside
Should go right on.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#5 | |
Bloo
they will fit, but the front is tight... if you do any flexy offroad driving expect to dent your fenders, my passanger side on bows out slightly from a tire hit. heres a pic of mine when it was clean for once with brand new 265/75/16 mud tires
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
i know this isn't exactly the same thing, but i had 275/55 20's on my 97, right around the 31.5-32" tall, and they didn't rub. never took it offroad of course
also, Blue_71, i'm from Morgantown(Butler County, Kentucky. nice to see a fellow Kentuckian on the boards ![]() |
Got 20's????
If you have stock wheels there will be absolutely no problem unless somebody has turned your torsion bars way down. Aftermarket wheels stick out more and would give you a chance of rubbing the fender if you bottom out on something nasty.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
Rusty Rockerfeller
![]() Join Date: May 2003
i have 305/70-16's on my 98 z71 and i have no problems at all
265/75/R16's are standard size on my truck.
GM RPO Codes '95 K1500 4x4 Ext Cab 5.7 TBI NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's |
