New parts stiffie
Hey guys and gals,
I recently replaced the power steering box, pitman arm, and idler arm on my 67 yesterday and it seems really stiff to go lock to lock. Is there normaly a break in period or did I screw screw something up. Box is a cardone reman and the pitman and idler are both moog. Mind you this is while it's still in the air. Looks like things are free no binding. Any ideas? TIA |
#2 | |
Re: New parts stiffie
![]() Join Date: Apr 2016
Sorry I gotta ask because you didn't say. Is this with a good working power steering pump that has fluid, and with the engine running, and did you bleed the air by going from lock to lock a couple times and add more fluid? Did you set up the power steering gear adjustments for thrust bearing preload and over-center preload yourself, or just use the steering gear as-is out of the box? What year is the power steering gear made for, I've heard that 67 is a different thing compared to later years, so wonder what is your setup. The adjustments are mentioned and excerpts from the manual in this other thread: http://67-72chevytrucks.com/vboard/s...d.php?t=812162
Hey guys, The box is a "new" cardone reman for a 77 C10. The truck had one in it when i bought it but it was sloppy and leaked. The numbers that were on the box indicated that was what year it was so i just went with that and along with the pitman arm for the same year. The idler is for my year truck a 67. The pump is a year old.
The procedure I did was top off fluid and turn the wheel lock to lock slowly with the engine running and topping off fluid as I went. I did this about 10-15 time the first time then had my son turn the wheel while I looked underneath to see if anything was binding this was an additional 5-8 more times. I did use the box as is out of the box. I didn't know that there was anything I was to adjust. I'll read the attached thread |
When you turn all the way to lock, it causes the pump to cavitate and prevents the system from bleeding properly.
Try jacking the front end up so the tires are off the ground. With the engine running, turn the wheel left and right about 20 times, stopping before you hit the locks.
Insert clever text here: |
#6 | |
I installed power steering on my truck using a Cardone gear box. The instructions that came with my unit said to jack up the frontend and turn the wheel lock to lock several times WITHOUT the engine running. Also made no mention of adjusting anything. I've had it on the truck almost 2 years with no problems.
![]() Join Date: Feb 2016
I just replaced the box and pump on my 67 with new Lares units. They seem stiffer or maybe it just has less assist than the old set up did. That being said it does seem slightly easier to turn now I have a couple hundred miles on it. (Or I've adapted)
I know I went from 4.75 turns to 3.5 turns and the old set up had that feather light 1960's Cadillac steering feel. So my information may not be the most helpful.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#9 | |
#10 | |
#11 | |
https://www.larescorp.com/toolbox/te...-instructions/
#12 | |
Shame on the parts supply for keep in your instructions. A lesson I learned a long time ago about returning cores.. Remove EVERY ITEM from the box before putting the old part in it. |
#13 | |
The Older Generation
Did you modify the frame or use spacers between the new box and the frame? Maybe the Cardone doesn't require it, but for most later power steering boxes installed on a '67 frame, either the frame needs modified or spacers used between the frame and steering box. LockDoc
#14 | |
#15 | |
