Old 03-06-2022, 02:13 AM   #14
stilldreamin6772
Re: New parts stiffie
Originally Posted by LockDoc View Post
Did you modify the frame or use spacers between the new box and the frame? Maybe the Cardone doesn't require it, but for most later power steering boxes installed on a '67 frame, either the frame needs modified or spacers used between the frame and steering box.
LockDoc
I did heat up the frame and bend it in some. Then used one grade 8 washer so the box clears the frame Because I couldn't get it hot enough with my Map gas torch to dimple the top part of the frame. There is a washer in all 4 holes so that it's not twisting.
stilldreamin6772 is offline   Reply With Quote
