Old 03-17-2023, 02:53 PM   #1
rws1012
LMC side fill tank
I bought this tank and have it installed in my 66 C10. There are 3 vent lines. How many vents do I need? LOL !!
How is the best way to terminate theses tubes?
LMC said they aren稚 techs or mechanics.
I am ususing mechanical fuel pump on my 250 ci engine. All help appreciated
rws1012 is offline   Reply With Quote
Old 03-17-2023, 03:52 PM   #2
Arne
Arne's Avatar
Re: LMC side fill tank
Probably designed to accommodate fuel injection with various return and evap lines. For carb use, I'd merge them into a single vent hose.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
覧覧覧覧覧覧
Arne is offline   Reply With Quote
Old 03-17-2023, 06:17 PM   #3
61hawk
61hawk's Avatar
I capped off the big tube with a rubber vacuum cap. The other two equal sized lines were run to rear stake pockets with a rollover vent cap. If you feed the line down from the stake pocket top you can screw the cap in from the bottom and you'll never see them.
https://www.summitracing.com/parts/TNK-VVR
61hawk is offline   Reply With Quote
Old 03-18-2023, 05:25 PM   #4
rws1012
Thanks. I will check out both ideas . Bed is off the truck now . Replacing brake lines and fuel line also.
