Old 02-06-2024, 02:27 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
WTB Good HEI core
Looking for a solid HEI core to rebuild and use. Doesn't have to have a cap, rotor, or module. Will buy and/or swap for other parts. Thanks.
Old 02-06-2024, 06:31 PM   #2
jimmy70
jimmy70's Avatar
Re: WTB Good HEI core
I've good a few Mallory HEI distributors / 1 complete / 1 core if interested.
PM a contact # and I'll shoot u a few pix. marko
jimmy70 is offline   Reply With Quote
Old 02-06-2024, 09:05 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Marko thanks. I’m aiming for a GM Delco example but I appreciate the offer.
Old 02-07-2024, 12:32 AM   #4
Burnsy01
Chevy Freak
Burnsy01's Avatar
I have Atleast one- I can grab you some pictures tomorrow .
Thank you
Nick
Nick
71 K20 5.9 p pump cummins (in progress)
68 Camaro 454BBC
86 Camaro 5.3LS turbo
Burnsy01 is offline   Reply With Quote
Old 02-07-2024, 08:34 AM   #5
Burnsy01
Chevy Freak
Burnsy01's Avatar
Let me know if this would work for you.
Nick
Nick
68 Camaro 454BBC
Old 02-07-2024, 12:53 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Nick that looks promising. Are you able to read the part number and date code on the body for me? Something like this pick but from a points distributor:
Old 02-07-2024, 12:54 PM   #7
Burnsy01
Chevy Freak
Burnsy01's Avatar
Sure I can take a look
Nick
68 Camaro 454BBC
Old 02-07-2024, 04:40 PM   #8
Burnsy01
Chevy Freak
Burnsy01's Avatar
Can you tell me where the part number is? I can’t find one. It’s definitely a factory gm hei I just don’t see a part number
Nick
68 Camaro 454BBC
Old 02-07-2024, 05:13 PM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sorry for the hassle. It should be stamped on the side of the aluminum housing at or near the level of the module and hidden by the cap. If you pop the cap off and look along the side it should be visible. Similar location to that for the points distributor. Thanks for the help.
EDIT - added HEI example
Old 02-07-2024, 08:20 PM   #10
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: WTB Good HEI core
If you are disassembling any old HEI, a new old stock Delco pickup coil, or pole piece as GM calls them is necessary. Those small wires work harden and break internally due to the back and forth motion caused by the vacuum advance, causing intermittent performance issues or outright failure. Also use a NOS Delco module and use the special heat dissipating grease on the bottom of the module. 1975 Chevy 350 pole piece is 1875981 D1907. The module is 1875990.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 02-07-2024, 08:30 PM   #11
Burnsy01
Chevy Freak
Burnsy01's Avatar
Okay 2 different codes-
1112977
5g24
Nick
68 Camaro 454BBC
Old 02-07-2024, 09:26 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
1112977
5g24
That works. Lmk what you need to get for it and thanks again.
Old 02-07-2024, 09:29 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for good info. I did source a NORS Standard pickup coil and have a store of USA made Echlin modules. I could use that module and will scrounge for one. The new HEI in the Blazer has been chronically problematic with warm starting. If I replace it with another HEI I want that to be solid since is just such a pita to get way back in there.
Old 02-07-2024, 10:27 PM   #14
Burnsy01
Chevy Freak
Burnsy01's Avatar
No problem- $40 shipped?
Nick
68 Camaro 454BBC
Old 02-07-2024, 10:32 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sure. Lmk how to square up. I’ll send a PM. Thanks again.
