Old 02-11-2024, 07:54 PM   #1
skokie
skokie's Avatar
Frame coatings that last
What type of coating would be used on a frame to ensure that it lasts as long as possible? I have heard of jet coating, powder coating and por15ing ( is that a word? It is now
Thanks guys and take care!
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-11-2024, 09:05 PM   #2
LS short box
Re: Frame coatings that last
Kind of depends what the trucks usage after you get it back together. I like powder coat. After sand blasting and powder coating the finish is very durable. My 98 Wrangler when I redid it I had the frame sand blasted and powder coated. It's been 15 years and still looks very good.
On the other hand my 80 Camaro project I sand blasted the parts and sprayed a single semi gloss black paint. It will never see a winter as long as I have it.
Powder will be tougher. Single stage paint will be cheaper and easy to apply.
Pics.
Old 02-11-2024, 10:11 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
I used chassis saver satin black on my K20 6-7 years ago and it has held up flawlessly so far. I wire wheeled the whole frame.
Tyler
57taskforce is online now   Reply With Quote
Old 02-11-2024, 11:54 PM   #4
allchevy58
allchevy58's Avatar
I used POR15 on my 64' Used wire brush then brushed on POR15, turned out nice.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 02-12-2024, 08:03 AM   #5
I would only powder coat a show truck. I prefer Mastercoat products over POR15. They are a step above. The founder is a chemist who helped develop POR15. He quit when they cheapened up on the ingredients.
www.nomorerust.com
Old 02-12-2024, 08:45 AM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Frame coatings that last
I used Mastercoat AG111 Ultimate Chassis Paint in satin black. It went on well, and is supposed to be super tough, It's formula has been used on subway cars in the past.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 02-12-2024, 09:51 PM   #7
BIG ORANGE
BIG ORANGE's Avatar
I used Duplcolor aerosol bedliner spray,
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 02-29-2024, 01:06 PM   #8
1969stepside
1969stepside's Avatar
https://www.amazon.com/Magnet-Paint-.../dp/B00EP8BRNC
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-29-2024, 02:08 PM   #9
Accelo
Accelo's Avatar
An excellent frame paint review. He really backs his choices with data.
https://www.youtube.com/watch?v=TABWPHutk-A
Cheers
Accelo is offline   Reply With Quote
Old 03-01-2024, 03:22 AM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Cheers
Wow, that was real good. POR-15, BLAH.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-01-2024, 10:12 AM   #11
Joyridin
I used Summit Racing chassis black paint. You mix their "thinner" with their paint and that is all that is needed. It came out awesome looking and it won't chip.
https://www.summitracing.com/parts/sum-up500q
I would go with powder coating if I had that option, but the chassis paint worked better than I thought. I have used POR-15 and personally, the stuff is a mess, hard to clean, and discolored after 2 years. I will never use it again.
Joyridin is offline   Reply With Quote
Old 03-03-2024, 07:31 AM   #12
LT7A
Pics.
You've got some cool projects. What did you paint the inner fenders on the Camaro with? I like that sheen. Less gloss than is typical.
On the question at hand, I have seen POR 15 layout really nice, glass like. But to my personal taste it's glossy. And it seems even when people buy the semi-gloss it still comes out pretty glossy. All depends on the look that you want.
Old 03-03-2024, 08:00 AM   #13
1970cstblazer
Exclamation Re: Frame coatings that last
One thing to remember, POR-15 is UV sensitive, therefore it must be top coated to ensure durability.
Personally I don't like the stuff, and obviously there are better products on the market that actually deliver and don't require a topcoat.
Old 03-03-2024, 11:11 AM   #14
Accelo
Accelo's Avatar
POR15 also comes in semi-gloss black.
Last I looked it was $44 a pint, $67 a quart.
Disclaimer, I have used it once.
I couldn't get the lid off a new can. Had to return it for another.
I was told it hardens using the moisture in the air.
The chances of saving any for later is low.
Old 03-03-2024, 11:19 AM   #15
raggedjim
raggedjim's Avatar
As soon as I open any of that moisture cure stuff I put it in a glass jar with a canning lid. The lid tops have a good seal and are cheap to replace.
The paint shop guy told me to put some welding shielding gas (argon is best but 75/25 will work) to displace the existing atmosphere in the top of the can. I never tried it but maybe that works.
Heck, sometimes I struggle getting the lid off of molasses!
raggedjim is offline   Reply With Quote
Old 03-03-2024, 01:08 PM   #16
Shortnwide4x4
Shortnwide4x4's Avatar
I have used eastwoods chassis black recently and it sprays well in a gun but comes in cans as well. it has a nice semi satin finish to it but i do not know how it will hold up over time. I have also used POR15 on another truck, mostly for inside areas i want to protect like inside doors etc. My last vehicle i had no issues with rust coming thru so i think it worked. it doesnt like UV so you cant use it where it will absorb UV or it will discolor to a brown hue. gross. I had it on a frame that sat outside without a body on it and it eventually just faded away 100% or flaked and fell off. This is the one i recently re-sprayed with eastwood after por15 disappeared
with P0r 15 i always considered the can single use. if you have leftover you have to find a mason jar to put the remainder in or you wont be able to open the can again. I think that does say something about its rust protection capabilities
Shortnwide4x4 is offline   Reply With Quote
Old 03-03-2024, 09:50 PM   #17
LS short box
So the 80 Camaro was a bit of a journey paint/powder coat wise. The car was a super clean 28K mile car when I bought it a couple years ago. Zero rust car. Not on speck due to being sprayed with rust proofing by Zeibart. So that was good. But when I was doing the LS swap I had the all the front end parts sand blasted in prep for powder coat. But in preparation for the powder the shop pre-heats the parts. As soon as they did that the Zeibart rust proofing turned to liquid and ran out from every where. So no go on the powder. I cleaned up the mess. The using spray bomb Rust-oleum primer and paint I just sprayed it. The paint is semi-gloss black. Turned out great in my opinion. Another pic of the 80.
The other pic is of my 68 C10. On that I did a satin black powder coat.
Old 03-04-2024, 02:53 PM   #18
70STOVEBOLT
70STOVEBOLT's Avatar
I used Rustoleum farm implement paint in "low gloss black". Wire brushed frame and brushed it on. It's been over 5 years and still looks good. I have only driven the truck about 500 miles though.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 03-05-2024, 03:24 PM   #19
crakarjax
crakarjax's Avatar
Red Oxide primer with your topcoat of choice
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-06-2024, 10:04 AM   #20
68 C10 Driver
I bought the Eastwood two part semi-gloss black chassis paint that will go over their rust encapsulator paint. I am hoping to start this chassis restoration in a few weeks. I have read good reviews on this and figured I would give it a shot.
68 C10 Driver is offline   Reply With Quote
Old 03-06-2024, 09:37 PM   #21
Hatzman
Hatzman's Avatar
Powder coat if at all possible. It is the best and I have used several different methods, including POR15, which eventually wears off, especially in the sunlight. (almost becomes powdery and can spear when you wipe it).
My last project on my 70 C10 was 90% black gloss, THAT was a mistake, too glossy.
Good luck!
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-07-2024, 08:01 AM   #22
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I won't use POR15 anymore. It will not adhere to nice shiny smooth steel. It likes to peel off. That sucks. The stuff isn't exactly cheap and is super hard to reuse if you don't use the whole can the first time.
Ryan
1969 Chevy milk truck
Old 03-07-2024, 09:44 AM   #23
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I use por 15 on my 70 jimmy
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 03-07-2024, 06:38 PM   #24
71CHEVYSHORTBED402
I used standard POR15 followed by their caliper paint with nice results. Matter of fact the shop I hired managed to lose some Dot3, I discovered weeks later. Some of the caliper paint was removed, but overall a pleasant surprise. I used their engine paint too, on the block, intake, water pump, thermo. housing and a clip or two. So far with real nice results. Other then that, perhaps, there are much better options.
Tony
Old 03-08-2024, 09:50 AM   #25
raggedjim
raggedjim's Avatar
Gary, did you spray it? If so what size nozzle did you use? It looks great!
