Old 06-16-2004, 01:16 AM   #1
nonstopproject
Question disc brake - front crossmember swap?
i read somewhere that you can unbolt the front crossmember, a-arms, spindles, disc, etc... as a unit from a 73-87 (not really sure on years) and bolt it under a 67-70 to convert it to disc brakes. not 100% on the details, but thats how the story went. is there anyone out there who has done this? how did it work? i'm new to the board, so thanks for any help.
nonstopproject is offline   Reply With Quote
Old 06-16-2004, 01:19 AM   #2
2low72
Welcome to the board. I have a friend here in abliene who did this. i'll try to get in-touch with him and find out the details
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 06-16-2004, 01:22 AM   #3
67cst
i love summertime
67cst's Avatar
i did this, ive got a whole 85 half ton front end on my frame rails, i believe there is 6 bolts a side and 5 of each line up and the 6th is just out a bit, with a dye grinder you can line them up and get the last bolt it, it was a real easy upgrade, i highly recommend it
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 06-16-2004, 01:31 AM   #4
nonstopproject
67cst: how much did you have to give for the whole front end? did you convert to power brakes too and if so which master cylinder/proportioning valve did you use? sorry for all the questions.
Old 06-16-2004, 06:12 AM   #5
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! Easiest way is to put booster, M/c and proportioning valve from 71/2 on it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-16-2004, 07:26 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
I did the swap also, super easy. altough I used the booster, master & prop. from the donor. did have to some fabbing for the pedal arm & linkage, but works & stops great.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-16-2004, 08:51 AM   #7
chevytruckfan
chevytruckfan's Avatar
Is easy. Just unbolt and remove the pitman arm from the steering box. Unbolt the flexable brake line and the bolts from the cross member to the frame. I did this as a unit with the wheels and tire still on so that I could line them up with the wheel wells and swapped it to a 47 so they pretty much fit all years. It is a weekend job and one of the easiest mods I have done.
chevytruckfan is offline   Reply With Quote
Old 06-16-2004, 09:24 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welcome to the board from southern oregon .. The swap is the easist way to get disk brake's and power steering..
FRENCHBLUE72 is offline   Reply With Quote
Old 06-16-2004, 06:26 PM   #9
WITHOUT_REASON
WITHOUT_REASON's Avatar
Just did a spindle swap from a 71 chevy with Disc brakes onto my 68. All I had to do was replace my Ball joints with 71 to 84 1/2 ton joints no changing cross member or tie rod ends and everything went together fine, gotta do some brake line mods but its still pretty simple..
WITHOUT_REASON is offline   Reply With Quote
