Does the temp light have a function in a truck with gauges?
I am also wondering if its supposed to light up while cranking the engine in order to test the bulb like in a modern truck? Mine doesn't light up at all.
Posted via Mobile Device Posted via Mobile Device |
Re: Does the temp light have a function in a truck with gauges?
All lights should light up when you turn the ignition on AFAI know. Yes a test signal is sent to show the light is working.
Back in the sticks
If I remember correctly, it won't. I swapped from idiot light to guages one time and you have to move a couple of wires in the dash harness for it to work right. Take a look at GMC Pauls website. He has a FAQ on there about it. I know on both of my trucks I have guages, and only the Brake light comes on while cranking.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-17-2010 at 08:04 PM. |
![]() Join Date: Mar 2000
Nope the temp light does not normally work in a gauge truck. You can however take the wires out of an idiot light truck and insert them into the gauge harness and terminal blocks/connectors. The clusters circuit board has the trace in it to that bulb location. Add the bulb to the cluster and put an indicator light sensor into the other head and a way you go. Take it a step further and plumb a tee into the oil pressure port and add the indicator light sender and tee that wire into the wire for the indicator for the temp sender and you will have a check engine light of sorts. Either will trigger the temp light and you will know to check your gauges.
Saskatoon, Saskatchewan Canada |
its all about the +6 inches
there shouldn't even be a light bulb or holder in there on a guage truck.
I was thinking of using the space as an indicator to remind me when I'm in four wheel drive. My 87 K5 Blazer has one in the same position, I thought it would be nice as I have actually forgot to take it out of 4 wheel drive a few times. I will throw a switch similar to a brake light switch against the lever under the boot and find a "Four wheel drive" lens to mount in the temp space indicator. Voila! Welcome to the 80s!
If I can ever get my TBI back on track I plan on using it for a SES light. I'm going to get a bulb holder and cut the metal tabs off. Then solder some wires to go out the back of the holder to wire it up.
![]() Join Date: Jun 2006
I used my temp light hole as a alt charge light. On when not charging ( I have a CS alternator with one wire turn on and the stud wire back to battery. I actually took a spare 194 plastic bulb holder like for a side marker and filed the tabs till it fit in the temp light hole.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
