Old 08-31-2006, 10:18 PM   #1
Malibu 496
Junior Member
Malibu 496's Avatar
couple ?'s
How can you tell if you have a double wall top?
How heavy are the top's?
Malibu 496 is offline   Reply With Quote
Old 08-31-2006, 10:23 PM   #2
Patch
Patch's Avatar
Re: couple ?'s
Double wall......bolts bottom up......single wall....top down. Double wall....like I have.....no idea on weight.......but I'd guess from lifting mine....about 200-ish.....Single wall weight....I have no experiance on that one.....
Patch
Patch is offline   Reply With Quote
Old 08-31-2006, 10:33 PM   #3
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: couple ?'s
I've got the double wall then I guess too. Is one more valuable than the other? My dad and I took mine off and it was pretty tough. Three people would make more sense.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 08-31-2006, 10:39 PM   #4
Patch
Patch's Avatar
Re: couple ?'s
I've heard that more people want the singles.....but I personally like my double.....Three people definately works better......The single wall tops also have curteousy lights on one side I think....
Patch
Old 09-02-2006, 08:18 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: couple ?'s
Patch got most of it right, Yes a single has dome lights in it, the same
oval type like in a regular cab truck, the advantage to a Single wall is
that IF you have rear cargo panels they will have to be removed with
a double, where as in a Single wall since it bolts from the top down the
panels do not need to be removed to get the top off, and if you have
a 72 model it is possible that your bed rails are drilled for both, because
they do NOT use the same mounting holes to bolt on except in the frt.
on top of the windsheild, and in the back near the tailgate, cya later
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
