Hei
What is the advantage of going from stock distributor sytem to HEI? TF
![]() Join Date: Dec 1999
You don't have to mess with no points for one.
its all about the +6 inches
More dependable, better starting and better running through the RPM rage from a better, more dependable spark.
Also never dealing with the stupid points again in your life. |
cracker
hmm, well on mine, my old points distributor just plain old sucked. i like my HEI , all i can say is when you put it in you will notice a huge difference, and then you dont have to worry about adjusting the dwell or replacing your points or anything, and you can get those big high power coils hehe
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
#1 reason is that points/gap lose spark at 4500 drastically. I had points/gap on my truck and did a top speed run and the revs stopped at 4500rpm cause my spark got too weak to push it further. (got it to the P in MPH though
![]() Happy Trucking. CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
SLOW BUT SURE,BUT CLOSER
Hey Frog, if you can get a HEI do it, makes life easier!!!!!!!!! I've used it for years.
69 C-10, OWNED 38YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
Hei
Thanks guys. Here goes a few more $$. TF
Old Skool Club
![]() Join Date: Jun 2001
If it is a rebuilt unit, you'll be ready to go when it is installed. If you buy a used one, be aware that there are a couple of components that are replaceable, when bad. The module and the capacitor that is attached to it, can go bad and your engine will die and not start until replaced. If and when you replace the module, be sure you use the correct heat sink compound that will be in the box with the module.
Other than that, you'll love the lack of maintenance required, compared to points-type. You'll have to install new plug wires....for a '76 and up V-8.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
