Old 02-05-2007, 09:39 PM   #1
fourty1
fourty1's Avatar
where to find passing gear/kickdown switch supplier
When the orig.327 was yanked from the engine bay of my 67 3/4 ton, the kickdown switch went with it.
I had a Transmission shop check it today, & they said i needed a ' kickdown' switch. I was led to believe it as an electric switch.
I have all the wires from the transmission.
I believe it was mounted on the intake manifold, behind the carb..
My engine bay now sports a GM crate 350, with the original transmission.
I'm looking for suppliers of this switch or ?
I've checked LMC ( pgs 117 detent cable )
and
YearOne ( pg 135 kickdown bracket )
BTW,... thanks,
jim
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine.
1967 Chevy 3/4 ton standard bed, 350 cu./400 auto,
w/ 83 - 3:43 rear end...sips gas....
fourty1 is offline   Reply With Quote
Old 02-06-2007, 12:32 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: where to find passing gear/kickdown switch supplier
Trucks up to 1970 used one bolted to the rear carb stud.. here is one on Ebay.. They tend to get quite expensive..
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Here is a reproduction bracket and a used switch from DR Classics.. scroll down to page 292..
http://www.drclassic.com/images/cata.../Underhood.pdf
Livrat is offline   Reply With Quote
Old 02-06-2007, 06:03 AM   #3
JimKshortstep4x4
The switches and brackets are available new and there are aftermarket versions. Attached is a picture of the original switch as installed. Also attached is a picture of the available parts with the vendor information.
Jim
Old 02-14-2007, 09:53 PM   #4
fourty1
fourty1's Avatar
FYI , Thanks for the info LIVRAT & JimK SHORT STEP 4x4:
My supplier , had a Hurst universal kickdown assembly,( as pictured above in the Firstgen.com catalogue page 43, priced at & 29.95 packaged as a
B&M Kickdown switch kit # 20297, priced at $ 48.oo. Installing tomorrow,...
jim
