Old 08-31-2007, 02:09 AM   #1
67 cst swb
67 cst swb's Avatar
lowering/tires/rims....Q? is anyone here running...?
Ok, I know this subject is over talked about,... BUT...
Is anyone here running a 2.5" front drop, 4" or 5" rear drop...
(here's the key thing for me)
With a 255/70-15 or 235/75-15 tire up front & a 265/70-15 tire in the rear?
OR if your running big rims...
a 28.9" or 29" tall tire up front & a 29.6" or so tire out back?
I'm thinking of running this combo on my project truck. But am nervous about this exact combo. I've never ran such a small tire height difference...
I've always ran (personal rule) 1.5" to 2.5" stagger in suspension lowering (ie... 2.5"/4" or 2.5"/5") then (next personal rule) 1.5" stagger in tire sizes(example... 27.5" tire in front w/ 29" tire in rear) I've never ran the front to rear tires so close in size... I'm wondering if this exact combo would work visually for me...
I'm just hoping someone has this combo already, if not,... then something close to it...
Show me what you got, anything CLOSE might help...
And for my next personal opinion....
I think any tire shorter than about 27" tall (255/60-15) looks wrong on our trucks,... now before you start hating me... some of these big rim trucks flirt with this and pull it off, they look good. But, I guess what I'm saying is... I don't really like the small diameter tire look to much...
remember, just my opinion....
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 08-31-2007, 07:11 AM   #2
71see10
Worthless
71see10's Avatar
Re: lowering/tires/rims....Q? is anyone here running...?
Dont know if this will help but heres mine with a 2 1/2 front and 5" back with 255/70/15 all around.give you alittle visual!!
71see10 is offline   Reply With Quote
Old 08-31-2007, 09:07 AM   #3
67 cst swb
67 cst swb's Avatar
perfect example...
anyone else?
My Trucks:
Old 08-31-2007, 10:38 AM   #4
pitt
69 GMC of DOOM
pitt's Avatar
fro a 2.5 drop in front... id only drop it 3 or 4 inches in back... and run about a 305 70R 15 tire on a 12 in wide rim. in the rear... i just like big tires in the back lol. and in front a 255 65R 15 on a 10 in wide rim in front...
pitt is offline   Reply With Quote
Old 09-01-2007, 12:50 AM   #5
dave2953
Dave's not here, man
dave2953's Avatar
Here's mine. It'll make you throw up in your mouth a little, but it does have a ~2.5/5 drop. Tires are 235/75/15. Hey See Ten, have you ever owned a vehicle that wasn't gorgeous?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 09-01-2007, 01:22 AM   #6
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Originally Posted by dave2953 View Post
Here's mine. It'll make you throw up in your mouth a little...
you are correct my friend
quite the interesting paint scheme you have there...
IvelDesigns is offline   Reply With Quote
Old 09-01-2007, 10:44 AM   #7
dave2953
dave2953's Avatar
That's what happens when you and your roomates get drunk and decide to start sanding and priming your truck.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 09-01-2007, 09:34 PM   #8
xmitsu10
xmitsu10's Avatar
Hi Brian,
Here is my '71 with a 3.5" drop up front with 255/60/15 on 8x15 wheels and 5" drop out back with 275/60/15 on 10x15 wheels. If I had not put the 1" drop springs and let it ride on only the spindles, I think the truck would sit level. I had hoped to drop it another 1" out back but have interference issues (rear is leafs). Not sure what the overall diameter of the tires are but I am sure you know.
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 09-01-2007, 10:39 PM   #9
70c10
67-72 Addict!
70c10's Avatar
xmitsu10- that stance is perfect!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
