Old 01-13-2008, 06:28 PM   #1
prg machine
prg machine's Avatar
clutch plate position
kind of a dumb question..but if you're not sure ask.right??
the friction plate for my small block.............simply put,,, which way does it fit against the flywheel??
with the part of the disc and springs that is the tallest in the center away from the flywheel or towards it..???????????????
thank you.
The splines have a taper for the engagement on one side for the trans input shaft,, I asume this goes towards the transmission......
prg machine is offline   Reply With Quote
Old 01-13-2008, 07:27 PM   #2
prg machine
Re: clutch plate position
ttt
Old 01-13-2008, 07:55 PM   #3
crazy longhorn
Fabricate till you "puke"
talllest part in the center toward the trans......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-14-2008, 05:07 AM   #4
LONGHAIR
Yeah, what he said ^^^
LONGHAIR is offline   Reply With Quote
Old 01-14-2008, 05:26 PM   #5
prg machine
Makes sence afterall.. that 's where the lead in is to the splines... for tranny shaft..
all of the books say "side marked flywheel side towards flywheel" which in my case there is nothing marked.
Thanks again guys...........it's great to have a second opinion..
