Old 05-02-2008, 06:50 PM   #1
jdmaffeo
jdmaffeo's Avatar
The plot thickens...
So I started to dismantle the front clip so that I could clean up my firewall and put in a new windshield seal as I have had a leak for a while. The windshield was a piece of cake to take out. I can only hope that it is that easy to put back in! Whoever installed it the last time didn't even use any sealer on the windshield itself! Leak number one. Upon tearing the seal off of the cab I found a little surprise. Leak number two...a hole the size of a dime right in the bottom middle of the windshield. So much for a quick clean up and put it back together...Here are a few pictures...What do you all use to remove the windshield sealer that someone used to adhear the seal to the cab?
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop.
jdmaffeo is offline   Reply With Quote
Old 05-02-2008, 06:52 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: The plot thickens...
You don't need sealer on these trucks. Every one I have had, and replaced, never had sealer under it. More than likely the gasket was just bad and never replaced.
bigblock73 is offline   Reply With Quote
Old 05-02-2008, 07:03 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Don't you realize by now that 9 times out of ten when you tear into something on one of these the plot ALWAYS thickens?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 05-02-2008, 07:54 PM   #4
mhicks
mhicks's Avatar
I had my windshield replaced on my '73 by pros about 8 months ago and they didn't use any sealer.
mhicks is offline   Reply With Quote
Old 05-02-2008, 08:28 PM   #5
jchav62
1962 C-10
jchav62's Avatar
No sealer necessary....
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-02-2008, 09:49 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
i wonder if that hole started out as someones access to the cab with wiring or something?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-02-2008, 10:35 PM   #7
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
winshield antenna???
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 05-02-2008, 11:50 PM   #8
slug
slug's Avatar
i had the same problem, but mine was way way worse than yours, do you have acess to a mig welder?? i even hear there is a product out there thet you can use to glue sheet metal together. you may want to look into that.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 05-03-2008, 05:16 PM   #9
jdmaffeo
jdmaffeo's Avatar
Someone definately used some kind of sealer between the cab and the seal. It hardened up just like the rubber. It is even hard to cut with a razor blade. I will have to get it all cleaned off and prepped for the new seal and fix the rust hole. I do have access to a mig welder, so that will definately speed up the process. I will be cutting it out tonight and hopefully welding in some new metal. I hope that it isn't all the way over to the mount for the windshield wiper. It is almost directly in front of the windshield antenna. I was hoping for just a quick little change out of the seal, but as any project there was a speed bump. I need to get the truck inspected by the end of May so I will have to pick up the pace a bit to meet that goal! I want to do a quick clean up of the firewall, inner fenders, and fenders. I think that it is possible as long as I don't run into any more surprises!
