Old 10-13-2008, 10:49 AM   #1
soba_03
soba_03's Avatar
Sticky steering wheel?
I got a realy nice wheel but it's all sticky. I've scrubed the crap out of it and it's better. However everything I've read on this subject says that it will come back once it get a good bakeing in the sun. Anyone come up with a solution? I was considering painting it with some clear, but i don't know if it will work. It's a 70-72 wheel with the rubber injection moulded plastic.
Any ideas would be great. Thanks...
soba_03 is offline   Reply With Quote
Old 10-13-2008, 11:03 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Sticky steering wheel?
I have used a product called GOO-GONE that worked good. Just saturate a small rag or old wash cloth and wash it down. It should be available at your local Wally World or major drug stores. Give one of them a call and see.
LockDoc
Leon
Old 10-13-2008, 11:27 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Brake parts cleaner on a rag works well too.
sneakysnake is offline   Reply With Quote
Old 10-13-2008, 04:30 PM   #4
soba_03
soba_03's Avatar
I've heard that no matter how much you clean it that the stickyness will come back... any experience with that?
Old 10-13-2008, 05:31 PM   #5
wig
I've found that anytime I park a truck it does that.I use windx.once you star trying it,it be cool.
wig is offline   Reply With Quote
Old 10-13-2008, 05:34 PM   #6
wig
I forgot to put,It wont come back as long as your driving it.
Old 10-13-2008, 05:39 PM   #7
john
member #16
john's Avatar
Alot of stuff will work, I used laquer thinner and then 303 leather vinyl protectant to bring the color and sheen back and its been okay for ten years.
john is offline   Reply With Quote
Old 10-13-2008, 05:47 PM   #8
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
After you clean it it should be fine...
It does seem like they don't get sticky if you drive them every once in a while.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 10-13-2008, 06:30 PM   #9
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
get yourself a few of those cheap Mr. Clean Eraser type things from a Dollar General and some goo gone and go to town on the wheel. That's what I used on my 3 spoke steering wheel when I was restoring it. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-13-2008, 06:40 PM   #10
leddzepp
Moderator
leddzepp's Avatar
How did your new tranny linkage go?
Old 10-13-2008, 10:25 PM   #11
soba_03
soba_03's Avatar
Zepp, It will work fine found out that there is not movement in my steering coulmn. So I can't adjust from there. It's got a thm350 in it and a PG column that is froze up. Just Saturday I Got a 72 thm350 column and it's PURDY.. I'll drop it in this weekend and dial the shift linkage in.. Thanks... bought the column for 50 & Guy didn't have change for the 3 20's I gave so got a prefectly good un cracked wheel and horn buttlon for $10. Yeah I'm living right.... thanks....
