Old 02-04-2009, 10:41 AM   #1
brew8
Front Brake Hoses
I'm trying to find a source for the factory front brake hoses for a 63 4x4 with the drum brakes. I included a picture, most part vendors show the larger hose end for that year of truck, have any of you found a source for the correct hose, thanks, Larry
brew8 is offline   Reply With Quote
Old 02-10-2009, 11:29 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Front Brake Hoses
I got mine from Napa. They worked / fit fine. Price seemed right too. If I recall it was Raybestos hoses.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 02-11-2009, 12:00 AM   #3
brew8
The larger one are the ones that NAPA gave me they won't even fit the wheel cylinders that they had, they had nothing else to offer. If you have a part number I would appreciate it, Larry
Old 02-11-2009, 12:09 AM   #4
'63GENIII
'63GENIII's Avatar
Hey Larry, I just finished swapping out the axles on mine but I think we saved the hoses. I will take a look in the shop tomorrow and let you know. Chris
Chris
'63 k15 long step
Old 02-11-2009, 12:20 AM   #5
brew8
Great, I appreciate it, Larry
Old 02-11-2009, 03:14 AM   #6
Rack Man
I've mainly used my local Hydraulic hose guy..."Hosepower USA".....They had a complete brake fitting dep't......So I simply had them make me up custom hoses....$70 for the both fronts...
One other time they did not have the correct fitting for a hose I needed so they "re-captured" the fitting off of my existing hose....worked perfect and they even polished it up to look like new....
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 02-11-2009, 08:42 AM   #7
brew8
Thanks Rack man, I have used the farm hydralic store for PS hoses, I'll look around, thanks again, Larry
Old 02-12-2009, 02:48 AM   #8
MickMc
MickMc's Avatar
Do you want factory replacement hoses or are you interested in braided stainless steel hoses?
Mick
MickMc is offline   Reply With Quote
Old 02-12-2009, 03:05 AM   #9
'63GENIII
'63GENIII's Avatar
Hey Larry, I just got in from the shop. I did look for them but it appears they got tossed. I did get them at the local Napa though. Sorry, Chris
Chris
'63 k15 long step
Old 02-12-2009, 08:43 AM   #10
brew8
Thanks for looking Chris, Mick, I just want some newer hoses so they work well and are safe, braided steel are fine with me, Larry
Old 02-12-2009, 11:38 AM   #11
MickMc
MickMc's Avatar
A couple of adapters from the frame brake line (pictured)
And a couple of adapters at the brake drum, I don't have a picture, but an easy find, either 3/8 to -3 or 7/16 to -3 male.
Then Smileys in Texas for the -3 braided brake line.
Measure the length you need and make phone call.
Mick
Old 02-12-2009, 06:29 PM   #12
brew8
Great info, I'll do that, thanks all for the help, Larry
Old 02-13-2009, 01:13 AM   #13
Blue_71
Bloo
Blue_71's Avatar
have you checked rockauto.com? they have some "oddball" stuff
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 02-13-2009, 09:06 AM   #14
brew8
I had not heard of them I'll give them a look as well, thanks, Larry
Old 02-13-2009, 11:20 AM   #15
MickMc
MickMc's Avatar
www.Smileysracing.com
http://www.smileysracing.com/cat/vie...0c453&pgID=725
Mick
Old 02-13-2009, 08:35 PM   #16
Blue_71
Bloo
Blue_71's Avatar
i checked, the higher end grade at rockauto, is around $30 each. it is part number bh34466
1989 Chevy K2500
Old 02-13-2009, 09:33 PM   #17
brew8
Thanks guys I'll check them out at Rockauto, thanks again, Larry
