Old 03-25-2009, 05:01 PM   #1
truckdude239
truckdude239's Avatar
electric choke
how should i go about wireing the choke on a 4 bbl qjet with electric choke. i just ordered one and was tring to figure it out before it got here
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-25-2009, 05:08 PM   #2
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: electric choke
Good ???
As I too need to wire up one on my Holley.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-25-2009, 05:22 PM   #3
Wrenchbender Ret
Re: electric choke
Wire it to a source that comes on when the key is on & go through a fuse. Actually the factory has an oil pressure switch wired in the circuit so if the key is on & the engine is not running it won't heat the choke off, but it is not nessesary.
Wrenchbender Ret is offline   Reply With Quote
Old 03-25-2009, 05:29 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: electric choke
I'd just wire it to the HEI. It hardly takes any amps to run the choke, and once the choke is closed, it isn't taking any power.
Old 03-25-2009, 06:08 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: electric choke
Another popular place to connect the choke wire is to the wiper motor wire, which is hot any time the key is on or in run. The choke wire feeds the coil inside the choke housing and it draws power anytime the key is on. The coil's purpose is to heat a bi-metallic spring inside the choke housing which opens the choke plate on the carburetor.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-25-2009, 06:52 PM   #6
truckdude239
Re: electric choke
well i dont have hei but i can run it to a power soruce that only hot when key is on that i can do
David fuller
2000 Tahoe 5.3l 378
Old 03-25-2009, 09:12 PM   #7
Senator350
Senator350's Avatar
Re: electric choke
otherwise known as an "ignition hot"
RN U OVR
Senator350 is offline   Reply With Quote
Old 03-25-2009, 10:08 PM   #8
Luis_gz06
Luis_gz06's Avatar
Re: electric choke
What part of the HEI do you hook it up to?
1972 Chevrolet Blazer 4x4 (Almost done stay tuned)
1970 Chevrolet Pickup Longhorn CST/20 (SOLD)
Luis_gz06 is offline   Reply With Quote
Old 03-26-2009, 06:46 AM   #9
Ace in the hole
Re: electric choke
The same wire that energizes the HEI from the ignition
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
