Old 12-30-2002, 05:51 AM   #1
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Help with 3/4 ton rear axle
I just fried my rear axle in my 68 C-20, (4 bolts holding the pumpkin in were missing!) Ran it dry, and ate the pinion gear. Can someone tell me if it is a Dana or Eaton, and what should I do to get it rebuilt or should I hit the junkyards? I just put this in 4 months ago after losing my 4.56, this one is a 4.10, and I would like to go higher, maybe 3.73. I think the bearings are still good. What is the typical cost to have one rebuilt?
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 12-30-2002, 09:16 AM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Because you can drop it out like that it is an Eaton. 4.10 is the best you can do unless you buy new gears. They make a 3.90 for it. Somebody on the board did this. If I remember right, it was over a $1000 to do! It would be worth the time to find a 14 bolt and change it over to fit your truck. I think 3.73's are pretty common.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-30-2002, 01:31 PM   #3
ThreeQuarter
ThreeQuarter's Avatar
Cobalt is the one who put 3.90s in his Eaton. And it was pretty expensive. Parts for these rear ends aren't cheap. Might I suggest you hit the junkyards in search of a Dana 60? You could find them with 3.54s, and if you really want 3.73s you can buy those for a D60, too. (But that ratio didn't come in D60s in these trucks.)
The Eaton is a far tougher rear end, and might be worth a rebuild if you need it, but the Dana is no slouch. Good luck.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
Old 12-30-2002, 04:25 PM   #4
COBALT
COBALT's Avatar
Yep, that was me.
I had 4.10 gears with a perfect ring and pinion, but the spiders were destroyed and the carrier bearings were shot. I got new 3.90s, and had a detroit locker put in (spiders and eaton posi aren't made any more unless you can find them used and in good shape).
Here's the break-down:
Carrier Bearings - $500 (they're monsters)
Detroit locker - $550
3.90s - $300 new
Labor - $250
Total - $1600
There's no point in replacing the ring and pinion without replacing the carrier bearings. Chances are they're in bad shape anyway, so you're looking at least $800 + however much you want to spend on a ring and pinion set.
My 4.10 gears are still in good shape with a good wear pattern and no chipping, and are sitting on my shelf since I had this done over a year ago. I'll give them to you for $75 if you want them.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
