Old 06-29-2009, 12:50 PM   #1
soule64
soule64's Avatar
One-and-a-half years later...
It's finally on the road again. Drove it to work today for the second test drive. Lots of fun if you don't mind the gas milage.
Before and after...
List of goodies...
GMPP ZZ383 Crate Motor
GMPP Serpentine Drive Kit
Holley 750 CFM
TH400 /Re-Sealed/cast aluminum pan
One-piece driveshaft with new yoke & bearings
Magna-Flow stainless exhaust
Aluminum HD Radiator
Summit electric fan/shroud
Optima Red battery/cables/Painless chassis wire harness
SSBC Disc brake system
Rear brake drums/shoes/wheel cylinders/springs
Stainless e-brake cables
2” Drop spindles w/new original height springs
4” drop springs w/adjustable panhard bar
Pitman arm/idler arm/ball joints/a-arm linkage/shocks
Chrome 15x8 Corvette ralleys/Uniroyal 265-70
Cab/core support/swing arm bushings
Front/rear chrome bumpers
Tilt steering column/Lokar linkage
Relocated Blazer fuel tank
½ door skins/fender pocket/rocker panels/cab corners/pillar panels/kick panels
Front grille/tailgate
Front windshield
Classic Auto Air system
New instrument cluster w/tach
Padded door panels/dash pad/carpet/seat cushion & cover
Vent windows/weatherstripping
Lizard skin sound deadener
Line-x bed liner
soule64 is offline   Reply With Quote
