Junior Member
ol curt floor saga
Getting near the end on the floor. Made a quasi patch panel for the passenger side kick panel out of an old piece of sheet metal from a farm implement.
Now I started to remove a couple of seat bolts that I thought were coming out nicely when they snapped off. I tried several methods....welding a bolt to it and trying to get it out. Couldn't get a good ground and the weld would always break. Used an easy out and it was budging some....broke off the easy out! Next I just cut the section of the floor surrounding it out. After looking at it I wonder if I welded a piece of bar steel to the floor patch, welded patch to floor, marked seat hole, drill and then tap if that would work. Any thoughts?
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
Resistance is Futile
Re: ol curt floor saga
I would think that method should work just fine. Also noticed a square nut in your pic. You could probably weld that on your patch and have it 'pre-threaded'. Say 'Hi' to everyone at the hardware store again
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
SSN 706
You need to start a build thread and put your ? on there. Then I would'nt miss half the stuff you do.
Junior Member
Also noticed a square nut in your pic. You could probably weld that on your patch and have it 'pre-threaded'. Say 'Hi' to everyone at the hardware store again.
Unfortunately, they know way to well! ![]() You need to start a build thread and put your ? on there. Then I would'nt miss half the stuff you do. Looks like your plugging along. I have one started called ol curt progress, but it doesn't have very many followers, so I just post them seperate! ![]() ![]()
Rods
![]() Join Date: Nov 2002
I get my square nuts from mack botl and steel
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
Schlongbed MEMBER (heh)#15
well, you're committed now..lol
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
Junior Member
Or should be!
