Old 02-03-2003, 12:38 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
Quicker steering ratio?
It takes a good 5-6 turns of my steering wheel to get the truck turned. I'm just wondering if there's a quicker ratio steering box that would fit and wouldn't seem like I'm turning a semi. Or would a smaller steering wheel do what I'm looking for?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 02-03-2003, 12:50 AM   #2
Maximum Overdrive
December 21, 2012
I have never used their services but these guys should be able to convert your existing box to a quick ratio. quick ratio steering There may be a few others out there that can do this also.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 02-03-2003, 01:18 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Smaller steering wheel would not chainge anything...it would still be 5-6 turns...just have to spin the wheel faster to get the reaction out of the wheels.
Old 02-03-2003, 02:22 AM   #4
breeh
Recovering 67-72 Addict
breeh's Avatar
I suggest checking out AGR. They have several options available. I put one of their variable ratio boxes in and am very happy with it. Summit had the best prices when I was shopping.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 02-03-2003, 02:44 AM   #5
crazy longhorn
Fabricate till you "puke"
I think a smaller wheel gives a better feel. You will still have the same amount of turns,& have to work it a little faster as Longhorn mentioned, but you arm doesnt travel as far with a smaller circle.....it just feels better to me?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-03-2003, 03:53 AM   #6
68 Suburban
68 Suburban's Avatar
If it is a power steering box, you might try a box from the mid to late 70's. I have one from 77? and it is 3 turns. I had to change the pitman arm over to a 77 also. The hole that mounts on the shaft is bigger. Other than that it was a bolt in.
68 Suburban is offline   Reply With Quote
Old 02-03-2003, 09:37 AM   #7
crazy longhorn
I have an 84 Burb box on the longhorn, its also 3 turns lock to lock. I had to change the hoses, pump fitting, & the pitman to bolt it on (metric box)........crazyL
