I found a set of Motown 220 heads for $400.. opinions on my application.
I guess they were used in a drag car for a few passes. I had a leaking head gasket so I pulled my heads and I'm pretty much freshening up my top end. My lower end is all stock though. These heads are set up for a solid roller cam/lifters but they're swapping out the valve springs to stock springs so they work better for my application. I do plan on adding a cam and all of that good stuff in the future. Will these heads work well in in my application? These heads are around $1100 new.
My application: 350 cid Headers Edelbrok 1406 Carb Aluminum Intake Oreilly's Crate Motor Stock Internals Specs on the Motowns: 220 cc runners 64 cc chambers 2.05 x 1.60 severe duty valves New Comp 10 degree retainers & locks
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) Last edited by 420am; 10-21-2009 at 08:55 PM. |
Between Trucks...
Re: I found a set of Motown 220 heads for $400.. opinions on my application.
I think those 220 cc runners are going to kill low end torque on a stock motor.
Beat it to fit, Paint it to match... ![]() |
![]() Join Date: May 2007
Assuming you have a 350...way too big on the intake runner. Stock heads are in the 157 range and vortecs are 170. More suited for HEALTHY 400. It does sound like a decent deal though.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
That's a good price for just about any aftermarket heads. Buy 'em for that $400 & trade across for some heads better suited for your current set-up (or put them on the shelf for a future build).
He has a set of Vortecs that have quite a bit of machine work done to them and they're fresh that he said he'd let go for $400 also but I don't want to have to buy a new intake.
1972 Long Bed Cheyenne Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=285282 Waste my bandwidth and listen to some great tunes >> http://www.radioxenu.com (Live Shows with yours truly every Friday) |
Between Trucks...
You'd be better off with the Vortecs. There's a Summit branded Vortec intake for about $140.
Or.... buy the Motown 220's @ $400 & swap 'em for some built vortecs w/intake. Someone out there will have what you need. Like I said, that's a good price if they're legit (no hacking, un-trashed, etc...).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-21-2009 at 10:09 PM. |
Hmm. I think I'll try to talk him down on the Vortecs.
Went with the Vortecs
![]() now I just need to pull the press-in studs, tap for screw-in studs, then buy some guide plates, centerbolt valve covers and a Vortec intake.. dammit might as well throw a cam and lifters into the mix while I'm at it. haha ![]() ![]() ![]() ![]() ![]() ![]()
![]() Join Date: Jul 2000
You done good! Those 220 ports were WAY TOO BIG.
Your truck just picked up 30+ horsepower.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 10-24-2009 at 07:04 PM. |
