Old 11-04-2009, 05:29 PM   #1
SuperWho
What year rearend will fit in a 64 long bed
Just like it says. Need a new rear end, just curious what years will swap out.
Thanks in advance.
SuperWho is offline   Reply With Quote
Old 11-04-2009, 07:44 PM   #2
SCOTI
SCOTI's Avatar
Re: What year rearend will fit in a 64 long bed
Thanks in advance.
To keep track width the same, you can use up to the early 70 year model rear housings (they're also 6-lug as well). Late 1970 models are 6-lug but they started making them wider & 71-72's are wider + 5-lugs. The wider rears will still work but wheel back spacing requirements become more critical if the suspension is getting 'tweaked'.
What's wrong w/your current rear end?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-04-2009, 09:14 PM   #3
63deluxfleet
63deluxfleet's Avatar
not to hijack, but i have a 63, can i use like an impala (63-68)or camaro 67-69)rear end without modifications??
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 11-04-2009, 10:03 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Not without modifications.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-04-2009, 10:10 PM   #5
SuperWho
It's completely shot, housing and all. Cheaper to find a whole unit most likely.
Old 11-04-2009, 11:07 PM   #6
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Good to see another truck from Texas.
What Scoti said is pretty point on. You would want to get on from 65-69 as they are 30 spline and stronger then the 14 spline that is in the 63-64.
Captinfab was saying there is some question about the length of the 70 rear end. I guess we need to find someone with one to measure it. maybe the wanted to change the rear in that year but had a bunch of left over from 69.
Check out www.car-parts.com There is a bunch on there right about $125-150.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
