Gear Jammer
Something fell off my truck......
Finally got all the parts together for the front end! Started pulling it apart and got all the radiator hoses and a new radiator a short water pump. I'm purtty excited ! Here are some pics .
![]() ![]() ![]() ![]() Got a nifty little tool from the matco guy it's attachments that go in your air hammer to help reform body panels. Used them for where the cab hit the bed. ![]() ![]() |
![]() Join Date: Aug 2009
Re: Something fell off my truck......
great looking project, I would avoid using the air hammer on that area of the truck, from what it looks like it does not have a big enough surface area and is streaching the shi* out of the metal, all those streach marks will add up and the metal will be hard to work..I would use a bumping dolly or a stud welder and then the old shrinking disk, where is alpine Ca?? I may have a spare hood that is better than the one you got
Member of the longbed union.
you can get his hood, then cut up the one you have and send the part that holds the blinkers to me. If it's not rusted out. Mine looks like it was in a shreader.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
I have two spare hoods, one on my truck now that is rusted and one in the back that is crashed and repaired, not real pretty but not rusted, I was going to use it before I found a better one, after I get the new hood primed and fitted to the truck I will let you know, I may cut it up anyway for a few of the curved parts to repair my roof
Alpine is just east of San Diego.
Martin Gibson
USAF Retired 1964(-ish) C10 |
let me know if your going to cut up the hood and if the front peice is any good. mine is just too bad to patch.
#7 | |
Registered.........
![]() Quote:
Let me know, Pete
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
truckdrivinsob:
Good start on your project. Keep the photos coming of your progress and thanks for sharing. PS - I have a few hoods with various damage, but they can be cut up for the good parts some of you guys are looking for. Send me a PM with what you need and I will reply accordingly. Last edited by LILRED66; 12-02-2009 at 02:16 AM. |
#9 | |
Gear Jammer
#10 | |
![]() Join Date: May 2009
Ruffrida check out this thread.---Vernski ![]() |
Gear Jammer
I worked my ass off today and forgot to take the camera ! Oh well. Got the motor all back together and the core support on. I'm finding out that the cab is pushed back about a 1/4". I guess the easiest way would be to just loosen all the body bolts and line everything up then tighten down. Any suggestions ?
Should have the falcon tank in the frame rails by the weekend hopefully get it fired off ! Last edited by truckdrivinsob; 10-18-2009 at 11:40 PM. Reason: spelling |
Falcon tank? I take it you're moving your tank out of the cab; what and where is your new tank going to be?
Gear Jammer
Yah i'm bagging my wifes 60 falcon which we bought a brand new tank for. Now that its going to the ground it hangs to low so i get it. I am going to mount it right behind the rear axle in between the frame rails. Its 16 gallons so not that bad.
Gear Jammer
Finally got the tank in and the floor cut to sit the seat on the floor. Tank came out a lot nicer than i thought it would! Getting the gears done tomorrow. Its all coming together! Here are some pics the last one is with the seat test fitted. Gave me enough room ! Its hard some times being 6'2" and 360 !
#15 |
The tank looks like an excellent solution. I like the way you stuffed it in there. Thanks for sharing and keep us posted on your progress.
#16 |
Gear Jammer
Yah Tony i was really stoked on how it came out. More pics tonite going up to work on it somemore today.
