Old 01-06-2011, 12:17 PM   #1
monza1979
monza1979's Avatar
shuttering under load?
recently i took my truck wheelin, and upon this a had to pull my buddy out of the mud(dodge guy, what are you going to do?) and since then i have had this shuttering sensation while the truck is under load, whether it be just normal driving or haulin' something. almost feels like a miss fire, but not quite if that makes sense. same trip off road tho i punctured a muffler, my biggest question is, since it has true duals, would the difference in back pressure between banks be causing such a shutter from the engine under load? and i am confident that the sensation is coming from the engine, not drive line. what else could it be? info for the truck is in my sig if any of that matters. thanks ahead of time for any help.
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 01-06-2011, 12:43 PM   #2
kieth
kieth's Avatar
Re: shuttering under load?
If it is a manual transmission I would say clutch.......try it in a high gear from a standstill it the engine revs high its the clutch or its adjustment....
kieth is offline   Reply With Quote
