Old 01-17-2010, 02:35 PM   #1
Barn-core
Barn-core's Avatar
Lowered '64 trac bar & shock relocators
So I just ordered my 3/5 drop springs from CPP, but I'm cheap so I only got the spring and shock kit. From what I've seen it looks like I will need shock relocators and an adjustable track bar. Like I said I'm cheap, is there any way I can modify the stock stuff to work? Thanks, Barn-core.
Barn-core, contra mundum with a vengeance!
"Our lady of blessed accelleration don't fail me now."
Barn-core is offline   Reply With Quote
Old 01-17-2010, 02:46 PM   #2
MXmaniac
MXmaniac's Avatar
Re: Lowered '64 trac bar & shock relocators
You can modify the track bar by cutting it, setting it at the length you need, and sleeve the track bar at the cut with a piece of pipe and weld it back together. That's the route I'm taking.
CPPJeff just posted a pretty sweet deal on adjustable track bars though, $50 for forum members in case you hadn't seen that post yet.
I haven't decided on a good way to relocate the shocks for cheap, that's still on my list. Hopefully someone else will chime in with a good way to modify the existing components.
Oh, and welcome to the board!
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 01-17-2010, 03:36 PM   #3
SCOTI
SCOTI's Avatar
As MXmaniac indicated, shortening & re-welding the stocker is the cheapest option. You can also shorten it, thread the ends of each half cut (LH/RH thread), & use a tie-rod sleeve to make it adjustable.
CPP has a 'kit' currently discounted to board members that's a better deal because you really want the bar as long as possible to limit the amount of shift inherent w/a Panhard bar. You could do the adjustable set-up described above using 2 OE bars to end up w/a cheap, long, adjustable bar too.
As for rear shocks, if you get some 67-72 rear lower shock mounts, you can tweak them so they function just like the brackets in a $70 shock relocator kit (the pre-67 lower brackets don't work well w/modifying).....
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-17-2010, 10:51 PM   #4
Barn-core
Barn-core's Avatar
Thanks for the info guys. What is the difference in the aftermarket shock mounts? I understand their purpose is to re-gain some travel after lowering, but what exactly do they do? How/where do they relocate the shocks? Maybe I can't modify the stock ones, but what about just making some from scratch. Also how do I measure for the correct length for my trac bar?
Old 01-17-2010, 11:59 PM   #5
SCOTI
SCOTI's Avatar
They allow the upper mounting point to be raised approx 1.5" & the lower to be dropped 1.5". The shock is in the same location, the mounting points of each end are actually what's "relocated".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-21-2010, 12:19 PM   #6
Barn-core
Barn-core's Avatar
So how do I measure for correct trac bar length?
Old 01-21-2010, 02:09 PM   #7
SCOTI
SCOTI's Avatar
Set the truck @ ride height.
Center the rear housing w/the frame.
Measure the distance between the frame mount & the opposite rear-end mount.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-21-2010, 05:20 PM   #8
CPPJEFF
Hey guys the relocation kit and adjustable trac-bar we manufacture are both a must on any truck that has been lowered to the point where the shocks are laying on there side or the axle is no longer centered under the truck. Guys i understand money as it is tight for everyone so let me just give you guys a deal on the relocators and the bar. If you guys need pics of an install of those shock relocators let me know. Thanks
CPPJEFF is offline   Reply With Quote
Old 04-19-2010, 01:45 PM   #9
ibad57
ibad57's Avatar
so what price on kit with bar and shock locaters? also
need bolt in notch63-72cnk
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172
ibad57 is offline   Reply With Quote
Old 04-19-2010, 01:49 PM   #10
CPPJEFF
$100.00 for the relocators and tracbar.
Old 04-19-2010, 03:18 PM   #11
michael bustamante
michael bustamante's Avatar
dang now thats a deal! already have me a trac bar though (cpp long length bar)
1967custom
michael bustamante is offline   Reply With Quote
Old 04-19-2010, 05:17 PM   #12
CPPJEFF
Ok $50.00 for the relocators.
Old 04-24-2010, 08:31 AM   #13
ibad57
ibad57's Avatar
so is this the kit# 6572cdtbx because i just ordered and shock relocaters were an additional charge the price you im was fine but thought it included the shock brakets
shipping order has kenny light but its Tim light
Old 04-24-2010, 09:21 AM   #14
SCOTI
SCOTI's Avatar
You should prob call Jeff @ CPP. I wouldn't expect him to be able to decipher what you need (or want to know) by what you just typed. I had to read that multiple times & I'm still not 100% sure. Proof-reading & punctuation go a long way toward effectively communicating your needs (I'm not being the grammer police here either).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2010, 10:09 AM   #15
CPPJEFF
Good call, feel free to call me and i can answe any questions you have. Thanks 888-522-8303 ext 118.
