Old 07-22-2010, 05:02 PM   #1
Patriot
Question Dana 60 rear??
I bought a Dana 60 rear for only 100.00. The axle is a full posi and was said to have been from a 67-72 truck.
How can I verify this? I want to put this under my 1981 K5 Blazer.
I know I will need to weld new spring perches on it to fit my Blazer but thats no big deal, I just want it to be ALL chevy.
Thanks fellas in advance.
Patriot
Patriot is offline   Reply With Quote
Old 07-22-2010, 07:02 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Dana 60 rear??
well a Dana 60 is not a GM product....but you do see them on GM's products...and not only is it not a 9" F***...its bigger!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-22-2010, 07:28 PM   #3
clinebarger
Re: Dana 60 rear??
Chevy, Dodge & Ford have used Dana 60s over the years. Do you have a picture?
clinebarger is offline   Reply With Quote
Old 07-22-2010, 08:56 PM   #4
Big-Blue
Big-Blue's Avatar
Re: Dana 60 rear??
Note the "60" on the lower right under the boss. It's a little less than a half-inch tall.
Big-Blue is offline   Reply With Quote
Old 07-22-2010, 09:18 PM   #5
navysnipe
navysnipe's Avatar
Re: Dana 60 rear??
If you pull the cover off of the Diff this is what you should see if you have a POSI. And in the glove compartment it should say option G87 POWER LOK REAR AXLE on the SPID. This is off of a 72 GMC not sure if it's the same for a Chevy.
Navysnipe
navysnipe is offline   Reply With Quote
Old 07-22-2010, 11:46 PM   #6
ERASER5
ERASER5's Avatar
Re: Dana 60 rear??
6 lug or 8 lug? The width may be narrower than you want, depending on which year it was made. 67-70 1/2 are narrower that the late 70 -72 in the 6 lug version. I have no idea about the width of the 8 lug version.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-23-2010, 12:20 AM   #7
63chevyll
gets board easy.......
63chevyll's Avatar
Re: Dana 60 rear??
i would use a 14 bolt if it were me.
they are stonger than a 60 and will bolt right into your blazer
(ok 60's are pretty damn strong, but the 14bolts are just as good)
63chevyll is offline   Reply With Quote
Old 07-23-2010, 05:51 AM   #8
Blazer1970
Blazer1970's Avatar
Re: Dana 60 rear??
True dat. They are a lot stronger than a 60, all GM and will bolt right into your truck. If you really want to know the origin of the D60 that you have, get the BOM number that is stamped on the axle tube.
Blazer1970 is offline   Reply With Quote
Old 07-23-2010, 02:27 PM   #9
ERASER5
ERASER5's Avatar
Re: Dana 60 rear??
Sure, IF he want to go to8lug. The D60 could be 6 lug.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 07-23-2010, 04:48 PM   #10
kwmech
Re: Dana 60 rear??
The chevy dana 60s have 7 bolts holding the backing plate to the housing. If it has 1/2'' studs it is a 1970 and older. If it has 9/16'' studs then it is a '71- or '72. This is assuming that it is a 3/4 ton 8 lug
Old 07-23-2010, 09:05 PM   #11
ERASER5
ERASER5's Avatar
Re: Dana 60 rear??
Some may have 7 bolts, most have 10. Like mine.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
