Old 07-31-2010, 01:21 AM   #1
tonypaul
tonypaul's Avatar
Tilt steering swap
Has any one swaped in a tilt steering column from a newer truck? I want to have a cruise control stalk (engine swap) and would like to have my key in the column. I have already smoothed out all of the dash where the radio, heater/a-c, and the key cylinder hole already...
Thanks!
tonypaul is offline   Reply With Quote
Old 07-31-2010, 07:06 AM   #2
Thealien
Thealien's Avatar
Re: Tilt steering swap
Interested if you get some replies. It is probably doable?
Old 07-31-2010, 05:51 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll need to cut a larger hole in the bottom of the dash, figure out the ignition wires, highbeam switch wires, pipers if you go that new. Then the steering shft may need addressed too since it isn't the same as our trucks
