Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 10-13-2010, 12:46 PM   #1
djw32
Rebuilt GM 350
Fresh rebuilt 350
2 bolt main
Quadrajet Carb ( the carb shop)
HEI Dizzy
New GM starter
I have two different flywheels for this 350-1 for a turbo 350 and 1 for a 700R4.
I bought this motor from GM. I may have put ONLY 400-500 miles on this motor. Also, I took this motor out for a LS 5.3.
This motor is a ready to run (turn key) motor.
$2,400
Video of the motor running before it was pulled out.
Specs on the motor:
Block: Cast iron, 2-bolt main, 1-piece rear main seal
Connecting Rods: Powdered Metal Connecting Rods
Pistons: Dished Hypereutectic
Compression Ratio: 9.4:1
Oil Pump: High-Volume Oil Pump
Timing Chain: Morse link-type
Camshaft: Flat Tappet Hydraulic (Lift .382" Int/.402" Exh; Duration @ .050" 165.9° Int/174.8° Exh; Lobe Separation Angle 111.9°)
Cylinder Heads: 65.3cc chambers, 1.94"/1.50" valves, swirl port intake design (heads are not performance-oriented; intended for good bottom end torque and fuel economy; intake runner is restrictive because it has a ramp cast into the bottom of the bowl to promote high swirl)
djw32 is offline   Reply With Quote
