Old 12-19-2010, 10:44 AM   #1
shortbed70
shortbed70's Avatar
86 1ton fuel tank?
Do any of you guys know of a company I can get alot larger fuel tank for my 86 1 ton chevy? It has a 454 and single tank and I have no range for driving. Its like 16 gallons I believe.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-19-2010, 10:51 AM   #2
GM72K10
Next!
GM72K10's Avatar
Re: 86 1ton fuel tank?
truck should have a 20 gallon tank, why not just install a second tank?
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 12-19-2010, 11:19 AM   #3
shortbed70
shortbed70's Avatar
I think the truck came with two tanks but it dosnt have the second one on it. I just bought this thing and it runs like a scalded dog just cant go more than 110 miles without worrying about gas. I have to go and do some work on it today and Ill see what it would take to put duels on it again. It has the switch inside the cab but no tank.
Troy
Big Red Dog build
Old 12-19-2010, 12:32 PM   #4
wyattglock
wyattglock's Avatar
I dont know how motivated you are to install a second tank and go through the trouble of replacing the dash switch and the switching valve on the frame. But you could always do a blazer style tank at the rear of the truck and keep the extra stuff to a minimum. I know there are a lot of guys on the forum here that have done exactly that, most have excellent pics and info on it. Then you could get up to a 40 gal tank which would help out your range a lot.
I have just gone through and got both tanks working on my 454tbi crew cab, and I had to figure out the wiring because the PO had chopped the harness up so bad. Hopefully that isnt the case with your truck. Good luck with the project.
wyattglock is offline   Reply With Quote
Old 12-19-2010, 12:37 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
you can get the mounts and the larger tank on there on each side.. advance was cheaper when i did this kind of thing a year or so ago
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-19-2010, 01:07 PM   #6
shortbed70
shortbed70's Avatar
I dont know if I can put a tank in the back cause of the dump bed. I am going to load it on a trailer if I can find the weight of it somewhere to make sure Im not overloading it. Once I get it home then I can hunt around on it.
Troy
Big Red Dog build
Old 12-19-2010, 04:23 PM   #7
wyattglock
wyattglock's Avatar
That is a useful little bit of info about the dump bed. Now knowing that, I would also say another saddle tank is the way to go. It shouldn't be to hard to find a donor truck that has two 20 gallon tanks on it. I would definitely go ahead and replace the dash switch and the switching valve while doing the second tank. It would save a lot of heartache down the road.
Old 12-19-2010, 01:38 PM   #8
GM72K10
Next!
GM72K10's Avatar
the problem with larger tanks on a dump truck are you already have tight quarters with mufflers and hydraulic resevoirs, etc. Blazer tank may or may not be feasible, depends on mounting of other stuff involved. Here's how mine K30 dump is, my C30 dump is a little different.
86 K30 CUCV M1028A1
Old 12-19-2010, 02:05 PM   #9
pig rig
pig rig's Avatar
if you got a dump bed on it it would be an easy job hanging another saddle tank on it and all the hole should already be there
and gm72k10 nice kink in your radiator hose you may want to fix that because the gas will eat at that type of hose
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-19-2010, 03:34 PM   #10
GM72K10
Next!
GM72K10's Avatar
That radiator hose is a temp until the real filler neck is put on, you can also see I'm missing a muffler on the driver side. Work in progress. That pic was taken right before the dump body was put on.
86 K30 CUCV M1028A1
